Topic: Using MIDI controllers with RME Connector to control 12mics
I can find a few threads on controlling TotalMix FX with third party controllers but not the RME remote connector. I want to use a MIDI controller (Faderfox EC4) to control just the mic gains on the 12mics. Is this possible, has anyone done something similar?
I have UFX+ (Driver 13.09.23, Version 0.9827, revision 54
2 x RME 12mics (firmware 1.7.1)
Rme Connector V2.0 x64
I'm on 64bit win 10.
My setup has 2 x 12mics as remote stage boxes connected via ethernet + MADI optical. I found the ethernet connection better for control over the 12mics although this new connector version seems very quick too. I use the MADI optical to send audio. Essentially I can see two connections from my 12mics to my laptop in the RME connector.
I can see the FaderfoxEC4 as a Midi connection in the RME connector but I can't seem to pick up any midi commands from it to teach the Faderfox. I can see midi commands in BOMEsendSX picking up from the UFX+ MIDI port 3. I should add I am a total novice when it comes to MIDI.
I tried Tobias Erichsens RTPmidi to see if I could pick anything up from the web controller and forward it that way over the ethernet but I couldn't find the 12mics as devices on the network. I can find the IP addresses but I don't know how to find their port numbers.
Any advice would be greatly appreciated. If it's possible to do this but complicated then that would be good to know and I will employ an expert to help.
thanks Phil
