1 (edited by reljapg 2024-01-16 12:19:04)
Topic: M1 MBP 12.6 dont recognise old Babyface
Hi, I have been using old Babyface for 10 years. I didn't have any problems with the interface and suddenly my M1 MBP Monterey 12.6 dont see the Rme interface. Then I tried with new drivers but nothing, flash tool doesn't want to update. Does anyone have the solution for this problem?
2 (edited by waedi 2024-01-16 01:49:14)
Re: M1 MBP 12.6 dont recognise old Babyface
Sure the Babyface is not in CC-mode ?
Holding the two buttons "SELECT" and "RECALL" during power-up will flip between normal-mode and CC-mode.
Otherwise :
Install old driver 328B2 (just for performing the FUT)
Run FUT
Install new driver 409
Follow all instructions in the driver readme text and reboot the computer.
Babyface should work, check out with Totalmix.
And please, one posting is enough.
Thank you for the response and instructions.
BAbyface is not n cc mode. When I follow instructions from 328B2 everything works well, but the "grey allow" button doesn't appear in "System preferences- security and privacy". FUT still doesn't want to update. Then I install 409 and still nothing in the total mix.
Do you know what can it be?
Revert back to the 328 driver and read out the actual firmware in the Babyface.
And try again the FUT, again and again, once it performs successfully, then the driver update is to do.
