Topic: FF400 on intel mac mini 2018 TB3 with Sonoma
i tried with daisy chain (original apple adapters: FW 400/800 cable to FW800/TB2 + TB2/TB3)
the FF400 stays stuck with HOST red light on.
i cannot do nothing cause the mac doesn't see the FF...totalmix doesn't open, fireface settings doesn't open...
i succesfully installed the driver...
Re: FF400 on intel mac mini 2018 TB3 with Sonoma
In MacOS system report, if you plug in the adaptors without interface, do the adaptor appear in the report under thunderbolt ?
Sometimes original Apple adapters are broke new...
3 (edited by sseither 2024-01-22 20:47:04)
similar problem here.
FF400 ->FW 400/800 cable -> FW800/TB2 adaptor ->TB2/TB3 adaptor-> macbook pro 2023 on Sonoma 14.2.1
Driver driver_fw_mac_335.
No host connection, Toatlmix and fireface settings won't open.
I am not an apple expert but have a technical background.
Can anyone give me some hints where I can find the information to at least see what's not working. Which logfiles do I need to check or are there any diagnostic tools I could use to analyse whats not working correctly?
Any help is deeply appreciated.
Thank you in advance!
Edit, just a couple of minutes after posting the above:
I don't belive it, I just started working!!!
At least the red host connection indicator is gone, fireface settings works as expected, totalmix and also logix seem to work.
Have no idea what's different now...
at least they're cheap.... sad
sseither wrote:
lucky you!
poor me!
wink
