1 (edited by marcvalero 2024-01-20 18:10:19)
Topic: Problem with last update driver and Firmware(Windows 7)
i've updated drivers on my pc (windows 7) and firmware of my Fireface 802 today.
Since, i got issue with the asio Fireface usb who seems not to be recognized... and i can't use totalmix (only disconnected) so i can't work...
What's happened ???
I never had this problem before.
2 (edited by waedi 2024-01-20 21:40:31)
Re: Problem with last update driver and Firmware(Windows 7)
Did you cold reboot the PC ?
Shut down completely and reboot ? Not a normal reboot where the system keeps on power.
3
The last driver 1.249 might not be compatible to Windows 7 anymore, we are checking this. Go back to the previous one (1.246) and use the latest TotalMix FX with it. The firmware is backwards compatible, so no need to change.
And do you know how i Can have the driver 1.246 ? I didn't found it in archives...
5
Easy (and logical):
https://www.rme-audio.de/downloads/driv … n_1246.zip
Not to mention that Windows usually offers to return to the last used driver (via Device Manager). It's most probably still on the computer.
