Topic: Main Volume anomaly upon waking from sleep on MacOS
TotalMix v1.83
UCXII firmware v43 driver v4.08
MacOS 12.7.1
Lately something new has started to happen: Upon waking from sleep, main volume will be reset to 0dB or even higher resulting in deafening and painful loud sound. This has started after I changed the "Snapshots Do not load" from nothing to Main Volume.
For now I have changed it back to nothing, but I would like to be able to keep the main volume unaffected by snapshots without getting this level reset after waking up.
Thanks!
UCXII | ARC | MBP M1Max | MacOS 14.6.1
Re: Main Volume anomaly upon waking from sleep on MacOS
The actual driver version is 4.10
May be worth a try ?
3 (edited by zephonic 2024-01-23 06:14:07)
So I updated all relevant software, but the issue still occurs. Actually, now I have the "Snapshots Do not load" set to nothing and it doesn't make a difference, so I guess changing it to Main Volume was not what caused it.
TotalMix 1.93
UCXII Firmware: v43 Driver: v4.10
MacOS 12.7.2
So I tried quitting TotalMix before letting the computer go to sleep, and that does seem to help. The volume settings will be the way I left them upon waking up.
This is just casual observation, not scientific testing by any standard. But it does appear to be a communication error between TotalMix and the UCXII.
