Topic: Crash while sending OSC to TotalMix FX
While turning a dial and sending instruction via OSC to the gain of the Mic, TotalMix FX crashed.
TMFX v 1.93 MacOS (3)
RME Thunderbolt Settings Firmware: v112, Driver: v1.05
Fireface UFX+ (23919669) (the old hardware version, I guess: SW Version: 55, Active Nodes: 105
Mac OSX 12.7.2 (Monterey)
Translated Report (Full Report Below)
Process:               TotalmixFX [918]
Path:                  /Applications/Totalmix.app/Contents/MacOS/TotalmixFX
Identifier:            de.rme-audio.TotalmixFX
Version:               1.93 macOS (3)
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2024-01-30 17:07:14.3790 +0100
OS Version:            macOS 12.7.2 (21G1974)
Report Version:        12
Bridge OS Version:     8.3 (21P53030b)
Anonymous UUID:        5A0B290E-E516-F77C-ED47-46ED474D6274
Time Awake Since Boot: 380000 seconds
System Integrity Protection: enabled
Crashed Thread:        5
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x000000000000004c
Exception Codes:       0x0000000000000001, 0x000000000000004c
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [918]
VM Region Info: 0x4c is not in any region.  Bytes before following region: 140737486790580
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      VM_ALLOCATE              7fffffe82000-7fffffe83000 [    4K] r-x/r-x SM=ALI
Thread 0::  Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib                0x7ff81306596a mach_msg_trap + 10
1   libsystem_kernel.dylib                0x7ff813065cd8 mach_msg + 56
2   CoreFoundation                        0x7ff81316929d __CFRunLoopServiceMachPort + 319
3   CoreFoundation                        0x7ff813167928 __CFRunLoopRun + 1276
4   CoreFoundation                        0x7ff813166d6c CFRunLoopRunSpecific + 562
5   HIToolbox                             0x7ff81be195e6 RunCurrentEventLoopInMode + 292
6   HIToolbox                             0x7ff81be1934a ReceiveNextEventCommon + 594
7   HIToolbox                             0x7ff81be190e5 _BlockUntilNextEventMatchingListInModeWithFilter + 70
8   AppKit                                0x7ff815ba5f6d _DPSNextEvent + 927
9   AppKit                                0x7ff815ba462a -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1394
10  AppKit                                0x7ff815b96cd9 -[NSApplication run] + 586
11  AppKit                                0x7ff815b6ac57 NSApplicationMain + 817
12  dyld                                     0x10d22952e start + 462
Thread 1:
2   CoreMIDI                              0x7ff829de6284 XServerMachPort::ReceiveMessage(int&, void*, int&) + 94
3   CoreMIDI                              0x7ff829e166a5 MIDIProcess::MIDIInPortThread::Run() + 105
4   CoreMIDI                              0x7ff829dfd18e XThread::RunHelper(void*) + 10
5   CoreMIDI                              0x7ff829dfe3b3 CAPThread::Entry(CAPThread*) + 77
6   libsystem_pthread.dylib               0x7ff8130a24e1 _pthread_start + 125
7   libsystem_pthread.dylib               0x7ff81309df6b thread_start + 15
Thread 2:: AMCP Logging Spool
0   libsystem_kernel.dylib                0x7ff8130659a6 semaphore_wait_trap + 10
1   caulk                                 0x7ff81bba62e6 caulk::mach::semaphore::wait_or_error() + 16
2   caulk                                 0x7ff81bb8e148 caulk::concurrent::details::worker_thread::run() + 36
3   caulk                                 0x7ff81bb8de0c void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 41
4   libsystem_pthread.dylib               0x7ff8130a24e1 _pthread_start + 125
5   libsystem_pthread.dylib               0x7ff81309df6b thread_start + 15
Thread 3:: com.apple.CFSocket.private
0   libsystem_kernel.dylib                0x7ff81306dd4a __select + 10
1   CoreFoundation                        0x7ff8131905a9 __CFSocketManager + 641
2   libsystem_pthread.dylib               0x7ff8130a24e1 _pthread_start + 125
3   libsystem_pthread.dylib               0x7ff81309df6b thread_start + 15
Thread 4:: com.apple.NSEventThread
5   AppKit                                0x7ff815d1398e _NSEventThread + 132
Thread 5 Crashed:
0   TotalmixFX                               0x10a36a64c 0x10a2e0000 + 566860
1   TotalmixFX                               0x10a3696ad 0x10a2e0000 + 562861
2   TotalmixFX                               0x10a341fc1 0x10a2e0000 + 401345
3   TotalmixFX                               0x10a33e289 0x10a2e0000 + 385673
4   libdispatch.dylib                     0x7ff812eea317 _dispatch_client_callout + 8
5   libdispatch.dylib                     0x7ff812eecd7c _dispatch_continuation_pop + 453
6   libdispatch.dylib                     0x7ff812efe208 _dispatch_source_invoke + 2179
7   libdispatch.dylib                     0x7ff812ef01cd _dispatch_lane_serial_drain + 342
8   libdispatch.dylib                     0x7ff812ef0dfd _dispatch_lane_invoke + 366
9   libdispatch.dylib                     0x7ff812efaeee _dispatch_workloop_worker_thread + 753
10  libsystem_pthread.dylib               0x7ff81309efd0 _pthread_wqthread + 326
11  libsystem_pthread.dylib               0x7ff81309df57 start_wqthread + 15
Thread 6:
0   libsystem_pthread.dylib               0x7ff81309df48 start_wqthread + 0
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 5 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000700009e49610  rcx: 0x000000010a36ac40  rdx: 0x0000700009e49501
  rdi: 0x00007fc548040000  rsi: 0x0000700009e495e8  rbp: 0x0000700009e49690  rsp: 0x0000700009e495b0
   r8: 0x0000000000000002   r9: 0x000000010a381d37  r10: 0x0000000000000000  r11: 0x00006ffeffa4a5e3
  r12: 0x00007fc548083abc  r13: 0x00007fc54807e4f0  r14: 0x00007fc54807a670  r15: 0x000000010a3ff020
  rip: 0x000000010a36a64c  rfl: 0x0000000000010246  cr2: 0x000000000000004c
Logical CPU:     14
Error Code:      0x00000004 (no mapping for user data read)
Trap Number:     14
Thread 5 instruction stream:
  ff 0f 2e c8 75 1f 7a 1d-48 8b 85 38 ff ff ff 41  ....u.z.H..8...A
  80 bc c5 68 51 00 00 01-74 0b 41 80 7e 64 00 0f  ...hQ...t.A.~d..
  84 40 02 00 00 41 0f be-47 18 ff c8 83 f8 04 0f  .@...A..G.......
  87 30 02 00 00 48 8d 0d-18 06 00 00 48 63 04 81  .0...H......Hc..
  48 01 c8 ff e0 f3 0f 11-95 40 ff ff ff 49 8b 7e  H........@...I.~
  58 48 8d b5 58 ff ff ff-e8 87 b0 fe ff 0f 57 c0  XH..X.........W.
 [f3]0f 5a 40 4c 66 0f 2e-05 4f 92 05 00 0f 86 cc  ..Z@Lf...O......    <==
  00 00 00 0f 57 c0 f3 0f-5a 85 6c ff ff ff 48 8d  ....W...Z.l...H.
  35 c7 76 01 00 e9 6e 01-00 00 f3 0f 11 95 40 ff  5.v...n.......@.
  ff ff e9 da 00 00 00 0f-2e 05 82 d5 04 00 f3 0f  ................
  11 95 40 ff ff ff 0f 86-b8 00 00 00 c7 85 6c ff  ..@...........l.
  ff ff 00 00 c0 40 f3 0f-10 05 62 d5 04 00 e9 ae  .....@....b.....
Binary Images:
    0x7ff813064000 -     0x7ff81309bfff libsystem_kernel.dylib (*) <c37bfe8a-c5ae-3fe0-b722-33483d9017b9> /usr/lib/system/libsystem_kernel.dylib
    0x7ff8130e9000 -     0x7ff8135ebfff com.apple.CoreFoundation (6.9) <fb79a14a-fda9-3a3b-bc97-6eb525b794a6> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff81bdeb000 -     0x7ff81c0defff com.apple.HIToolbox (2.1.1) <913d3d2e-4e4c-3907-98fe-8f4abd551297> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7ff815b67000 -     0x7ff8169f6fff com.apple.AppKit (6.9) <322c1378-24a3-3361-97a1-8a487166d15b> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
       0x10d224000 -        0x10d28ffff dyld (*) <499010ac-3054-326e-a050-fefffb5ce89a> /usr/lib/dyld
    0x7ff829dd4000 -     0x7ff829e40fff com.apple.audio.midi.CoreMIDI (2.0) <a49983da-3693-3bc2-ba29-7c3ebde5a1d7> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x7ff81309c000 -     0x7ff8130a7fff libsystem_pthread.dylib (*) <e097f78f-fcfb-30f3-9164-dbc9709ba134> /usr/lib/system/libsystem_pthread.dylib
    0x7ff81bb8c000 -     0x7ff81bbadfff com.apple.audio.caulk (1.0) <f04b5c91-d0ec-33c6-8a81-b80a3ebf827f> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
       0x10a2e0000 -        0x10a3c7fff de.rme-audio.TotalmixFX (1.93 macOS) <a5ab285a-9727-3e43-99fb-df2d67a4d266> /Applications/Totalmix.app/Contents/MacOS/TotalmixFX
    0x7ff812ee7000 -     0x7ff812f2dfff libdispatch.dylib (*) <85c90f84-c537-3cc6-b795-a066e050ffe3> /usr/lib/system/libdispatch.dylib
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=2.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.8G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework              2688K       21
Activity Tracing                   256K        1
CG backing stores                 3648K        8
CG image                           684K       95
ColorSync                          232K       28
CoreAnimation                     30.3M      125
CoreGraphics                        16K        3
CoreUI image data                 4164K       54
Foundation                          92K        2
Image IO                           200K        2
Kernel Alloc Once                    8K        1
MALLOC                           503.4M       96
MALLOC guard page                   48K       10
MALLOC_MEDIUM (reserved)           1.9G       16         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
STACK GUARD                       56.0M       11
Stack                             13.1M       11
VM_ALLOCATE                       7128K       76
__CTF                               756        1
__DATA                            34.9M      419
__DATA_CONST                      23.0M      258
__DATA_DIRTY                      1045K      150
__FONT_DATA                          4K        1
__GLSLBUILTINS                    5176K        1
__LINKEDIT                       646.1M       14
__OBJC_RO                         82.9M        1
__OBJC_RW                         3200K        2
__TEXT                           362.3M      433
__UNICODE                          592K        1
dyld private memory               1024K        1
mapped file                      397.2M       42
shared memory                      792K       19
TOTAL                              4.4G     1904
TOTAL, minus reserved VM space     2.1G     1904
Full Report
{"app_name":"TotalmixFX","timestamp":"2024-01-30 17:07:16.00 +0100","app_version":"1.93 macOS","slice_uuid":"a5ab285a-9727-3e43-99fb-df2d67a4d266","build_version":"3","platform":1,"bundleID":"de.rme-audio.TotalmixFX","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.7.2 (21G1974)","incident_id":"BE4A66FF-8273-4252-8961-72F8FEB87AB8","name":"TotalmixFX"}
  "uptime" : 380000,
  "procLaunch" : "2024-01-26 05:45:13.1424 +0100",
  "procRole" : "Background",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro16,4",
  "procStartAbsTime" : 74211554463,
  "coalitionID" : 630,
  "osVersion" : {
    "train" : "macOS 12.7.2",
    "build" : "21G1974",
    "releaseType" : "User"
  "captureTime" : "2024-01-30 17:07:14.3790 +0100",
  "incident" : "BE4A66FF-8273-4252-8961-72F8FEB87AB8",
  "bug_type" : "309",
  "pid" : 918,
  "procExitAbsTime" : 386593762164653,
  "cpuType" : "X86-64",
  "procName" : "TotalmixFX",
  "procPath" : "\/Applications\/Totalmix.app\/Contents\/MacOS\/TotalmixFX",
  "bundleInfo" : {"CFBundleShortVersionString":"1.93 macOS","CFBundleVersion":"3","CFBundleIdentifier":"de.rme-audio.TotalmixFX"},
  "storeInfo" : {"deviceIdentifierForVendor":"0B871F0E-7C9E-5960-9937-A1F47ACADC62","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "de.rme-audio.TotalmixFX",
  "crashReporterKey" : "5A0B290E-E516-F77C-ED47-46ED474D6274",
  "bridgeVersion" : {"build":"21P53030b","train":"8.3"},
  "sip" : "enabled",
  "vmRegionInfo" : "0x4c is not in any region.  Bytes before following region: 140737486790580\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      VM_ALLOCATE              7fffffe82000-7fffffe83000 [    4K] r-x\/r-x SM=ALI  ",
  "isCorpse" : 1,
  "exception" : {"codes":"0x0000000000000001, 0x000000000000004c","rawCodes":[1,76],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x000000000000004c"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":918},
  "vmregioninfo" : "0x4c is not in any region.  Bytes before following region: 140737486790580\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      VM_ALLOCATE              7fffffe82000-7fffffe83000 [    4K] r-x\/r-x SM=ALI  ",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 5,
  "threads" : [{"id":6945,"queue":"com.apple.main-thread","frames":[{"imageOffset":6506,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7384,"symbol":"mach_msg","symbolLocation":56,"imageIndex":0},{"imageOffset":524957,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":1},{"imageOffset":518440,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":1},{"imageOffset":515436,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":1},{"imageOffset":189926,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":2},{"imageOffset":189258,"symbol":"ReceiveNextEventCommon","symbolLocation":594,"imageIndex":2},{"imageOffset":188645,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":70,"imageIndex":2},{"imageOffset":257901,"symbol":"_DPSNextEvent","symbolLocation":927,"imageIndex":3},{"imageOffset":251434,"symbol":"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":1394,"imageIndex":3},{"imageOffset":195801,"symbol":"-[NSApplication run]","symbolLocation":586,"imageIndex":3},{"imageOffset":15447,"symbol":"NSApplicationMain","symbolLocation":817,"imageIndex":3},{"imageOffset":21806,"symbol":"start","symbolLocation":462,"imageIndex":4}]},{"id":7661,"frames":[{"imageOffset":6506,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7384,"symbol":"mach_msg","symbolLocation":56,"imageIndex":0},{"imageOffset":74372,"symbol":"XServerMachPort::ReceiveMessage(int&, void*, int&)","symbolLocation":94,"imageIndex":5},{"imageOffset":272037,"symbol":"MIDIProcess::MIDIInPortThread::Run()","symbolLocation":105,"imageIndex":5},{"imageOffset":168334,"symbol":"XThread::RunHelper(void*)","symbolLocation":10,"imageIndex":5},{"imageOffset":172979,"symbol":"CAPThread::Entry(CAPThread*)","symbolLocation":77,"imageIndex":5},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":6},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":6}]},{"id":9818,"name":"AMCP Logging Spool","frames":[{"imageOffset":6566,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":107238,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":7},{"imageOffset":8520,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":7},{"imageOffset":7692,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":7},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":6},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":6}]},{"id":9942,"name":"com.apple.CFSocket.private","frames":[{"imageOffset":40266,"symbol":"__select","symbolLocation":10,"imageIndex":0},{"imageOffset":685481,"symbol":"__CFSocketManager","symbolLocation":641,"imageIndex":1},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":6},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":6}]},{"id":10260,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6506,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7384,"symbol":"mach_msg","symbolLocation":56,"imageIndex":0},{"imageOffset":524957,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":1},{"imageOffset":518440,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":1},{"imageOffset":515436,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":1},{"imageOffset":1755534,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":3},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":6},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":6}]},{"triggered":true,"id":39591054,"instructionState":{"instructionStream":{"bytes":[255,15,46,200,117,31,122,29,72,139,133,56,255,255,255,65,128,188,197,104,81,0,0,1,116,11,65,128,126,100,0,15,132,64,2,0,0,65,15,190,71,24,255,200,131,248,4,15,135,48,2,0,0,72,141,13,24,6,0,0,72,99,4,129,72,1,200,255,224,243,15,17,149,64,255,255,255,73,139,126,88,72,141,181,88,255,255,255,232,135,176,254,255,15,87,192,243,15,90,64,76,102,15,46,5,79,146,5,0,15,134,204,0,0,0,15,87,192,243,15,90,133,108,255,255,255,72,141,53,199,118,1,0,233,110,1,0,0,243,15,17,149,64,255,255,255,233,218,0,0,0,15,46,5,130,213,4,0,243,15,17,149,64,255,255,255,15,134,184,0,0,0,199,133,108,255,255,255,0,0,192,64,243,15,16,5,98,213,4,0,233,174],"offset":96}},"threadState":{"r13":{"value":140485293761776},"rax":{"value":0},"rflags":{"value":66118},"cpu":{"value":14},"r14":{"value":140485293745776},"rsi":{"value":123145468286440},"r8":{"value":2},"cr2":{"value":76},"rdx":{"value":123145468286209},"r10":{"value":0},"r9":{"value":4466416951},"r15":{"value":4466929696},"rbx":{"value":123145468286480},"trap":{"value":14,"description":"(no mapping for user data read)"},"err":{"value":4},"r11":{"value":123141001356771},"rip":{"value":4466320972,"matchesCrashFrame":1},"rbp":{"value":123145468286608},"rsp":{"value":123145468286384},"r12":{"value":140485293783740},"rcx":{"value":4466322496},"flavor":"x86_THREAD_STATE","rdi":{"value":140485293506560}},"frames":[{"imageOffset":566860,"imageIndex":8},{"imageOffset":562861,"imageIndex":8},{"imageOffset":401345,"imageIndex":8},{"imageOffset":385673,"imageIndex":8},{"imageOffset":13079,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":9},{"imageOffset":23932,"symbol":"_dispatch_continuation_pop","symbolLocation":453,"imageIndex":9},{"imageOffset":94728,"symbol":"_dispatch_source_invoke","symbolLocation":2179,"imageIndex":9},{"imageOffset":37325,"symbol":"_dispatch_lane_serial_drain","symbolLocation":342,"imageIndex":9},{"imageOffset":40445,"symbol":"_dispatch_lane_invoke","symbolLocation":366,"imageIndex":9},{"imageOffset":81646,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":753,"imageIndex":9},{"imageOffset":12240,"symbol":"_pthread_wqthread","symbolLocation":326,"imageIndex":6},{"imageOffset":8023,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":6}]},{"id":39598020,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":6}]},{"id":39603381,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":6}]},{"id":39612268,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":6}]},{"id":39615901,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":6}]},{"id":39615902,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":6}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703447793664,
    "size" : 229376,
    "uuid" : "c37bfe8a-c5ae-3fe0-b722-33483d9017b9",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "x86_64h",
    "base" : 140703448338432,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5255168,
    "uuid" : "fb79a14a-fda9-3a3b-bc97-6eb525b794a6",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1866"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703596195840,
    "CFBundleShortVersionString" : "2.1.1",
    "CFBundleIdentifier" : "com.apple.HIToolbox",
    "size" : 3096576,
    "uuid" : "913d3d2e-4e4c-3907-98fe-8f4abd551297",
    "path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
    "name" : "HIToolbox"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703492894720,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 15269888,
    "uuid" : "322c1378-24a3-3361-97a1-8a487166d15b",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2113.60.148"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4515315712,
    "size" : 442368,
    "uuid" : "499010ac-3054-326e-a050-fefffb5ce89a",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703830982656,
    "CFBundleShortVersionString" : "2.0",
    "CFBundleIdentifier" : "com.apple.audio.midi.CoreMIDI",
    "size" : 446464,
    "uuid" : "a49983da-3693-3bc2-ba29-7c3ebde5a1d7",
    "path" : "\/System\/Library\/Frameworks\/CoreMIDI.framework\/Versions\/A\/CoreMIDI",
    "name" : "CoreMIDI",
    "CFBundleVersion" : "88"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703448023040,
    "size" : 49152,
    "uuid" : "e097f78f-fcfb-30f3-9164-dbc9709ba134",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703593709568,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.audio.caulk",
    "size" : 139264,
    "uuid" : "f04b5c91-d0ec-33c6-8a81-b80a3ebf827f",
    "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
    "name" : "caulk"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4465754112,
    "CFBundleShortVersionString" : "1.93 macOS",
    "CFBundleIdentifier" : "de.rme-audio.TotalmixFX",
    "size" : 950272,
    "uuid" : "a5ab285a-9727-3e43-99fb-df2d67a4d266",
    "path" : "\/Applications\/Totalmix.app\/Contents\/MacOS\/TotalmixFX",
    "name" : "TotalmixFX",
    "CFBundleVersion" : "3"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703446233088,
    "size" : 290816,
    "uuid" : "85c90f84-c537-3cc6-b795-a066e050ffe3",
    "path" : "\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
  "sharedCache" : {
  "base" : 140703444762624,
  "size" : 19331678208,
  "uuid" : "8ec191b8-2f89-31dc-ab61-d4a7547258ef"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)\nWritable regions: Total=2.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.8G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework              2688K       21 \nActivity Tracing                   256K        1 \nCG backing stores                 3648K        8 \nCG image                           684K       95 \nColorSync                          232K       28 \nCoreAnimation                     30.3M      125 \nCoreGraphics                        16K        3 \nCoreUI image data                 4164K       54 \nFoundation                          92K        2 \nImage IO                           200K        2 \nKernel Alloc Once                    8K        1 \nMALLOC                           503.4M       96 \nMALLOC guard page                   48K       10 \nMALLOC_MEDIUM (reserved)           1.9G       16         reserved VM address space (unallocated)\nMALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)\nSTACK GUARD                       56.0M       11 \nStack                             13.1M       11 \nVM_ALLOCATE                       7128K       76 \n__CTF                               756        1 \n__DATA                            34.9M      419 \n__DATA_CONST                      23.0M      258 \n__DATA_DIRTY                      1045K      150 \n__FONT_DATA                          4K        1 \n__GLSLBUILTINS                    5176K        1 \n__LINKEDIT                       646.1M       14 \n__OBJC_RO                         82.9M        1 \n__OBJC_RW                         3200K        2 \n__TEXT                           362.3M      433 \n__UNICODE                          592K        1 \ndyld private memory               1024K        1 \nmapped file                      397.2M       42 \nshared memory                      792K       19 \n===========                     =======  ======= \nTOTAL                              4.4G     1904 \nTOTAL, minus reserved VM space     2.1G     1904 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "61301e3a61217b3110231469",
      "factorPackIds" : {
        "SIRI_FIND_MY_CONFIGURATION_FILES" : "652886aa2c02f032beae8316"
      "deploymentId" : 240000028
      "rolloutId" : "6112e14f37f5d11121dcd519",
      "factorPackIds" : {
        "SIRI_TEXT_TO_SPEECH" : "634710168e8be655c1316aaa"
      "deploymentId" : 240000231
  "experiments" : [
Model: MacBookPro16,4, BootROM 2020.80.3.0.0 (iBridge: 21.16.3030.5.2,0), 8 processors, 8-Core Intel Core i9, 2,4 GHz, 64 GB, SMC
Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In
Graphics: AMD Radeon Pro 5600M, AMD Radeon Pro 5600M, PCIe, 8 GB
Display: Color LCD, 3072 x 1920 Retina, Main, MirrorOff, Online
Display: Thunderbolt Display, 2560 x 1440 (QHD/WQHD - Wide Quad High Definition), MirrorOff, Online
Memory Module: BANK 0/ChannelA-DIMM0, 32 GB, DDR4, 2667 MHz, SK Hynix, HMAB4GS6ABR8N-VK
Memory Module: BANK 2/ChannelB-DIMM0, 32 GB, DDR4, 2667 MHz, SK Hynix, HMAB4GS6ABR8N-VK
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 18:02:56 version 9.30.464.0.32.5.76 FWID 01-c081cfed
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Network Service: Belkin USB-C LAN, Ethernet, en9
PCI Card: pci1d18,1, Audio, Thunderbolt@72,0,0
PCI Card: Apple 57761-B0, Ethernet Controller, Thunderbolt@180,0,0
PCI Card: pci11c1,5901, IEEE 1394 Open HCI, Thunderbolt@179,0,0
PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@178,0,0
PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@178,0,1
PCI Card: pci12d8,400f, USB Enhanced Host Controller, Thunderbolt@178,0,2
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@187,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@185,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@184,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@186,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@194,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@193,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@191,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@192,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@201,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@200,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@198,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@199,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@207,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@205,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@208,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@206,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@215,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@213,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@214,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@212,0,0
Serial ATA Device: HGST HUH728080ALE600, 8 TB
Serial ATA Device: TOSHIBA HDWD130, 3 TB
Serial ATA Device: Hitachi HDS723030BLE640, 3 TB
Serial ATA Device: TOSHIBA MD04ACA400, 4 TB
Serial ATA Device: ST3000DM001-1CH166, 3 TB
Serial ATA Device: WDC WD4003FRYZ-01F0DB0, 4 TB
Serial ATA Device: ST6000NM0115-1YZ110, 6 TB
Serial ATA Device: Mercury Electra 6G SSD, 2 TB
Serial ATA Device: HGST HUS724030ALE640, 3 TB
Serial ATA Device: HGST HUS724040ALE640, 4 TB
Serial ATA Device: WDC WD4003FFBX-68MU3N0, 4 TB
Serial ATA Device: Hitachi HDS721010CLA332, 1 TB
Serial ATA Device: WDC WD4005FZBX-00K5WB0, 4 TB
Serial ATA Device: ST4000NM000A-2HZ100, 4 TB
Serial ATA Device: spsata_pm_name
USB Device: USB20Bus
USB Device: hub_device
USB Device: Apple Thunderbolt Display
USB Device: FaceTime HD Camera (Display)
USB Device: Display Audio
USB Device: USB31Bus
USB Device: USB2.0 Hub
USB Device: iLok
USB Device: Sensel Morph
USB Device: eLicenser
USB Device: Kensington Expert Mouse
USB Device: USB3.0 Hub
USB Device: T2Bus
USB Device: composite_device
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
FireWire Device: Vendor 0xA35 Device 0x101800, 0xA35, 800mbit_speed
FireWire Device: unknown_device, unknown_speed
Thunderbolt Bus: MacBook Pro, Apple Inc., 63.5
Thunderbolt Device: Fireface UFX+, RME GmbH, 3, 7.3
Thunderbolt Device: Thunderbolt Display, Apple Inc., 3, 26.2
Re: Crash while sending OSC to TotalMix FX
Could you provide more detailed infos about the exact OSC message you send to TM? which Input do you address?
Or better: the detailed OSC message and its values send out by your controller, and what you receieve (if you receive sth before crashing).
“Do It For Her”
I don't remember what the exact value was and what input I did address.
There is no value that crashes TM FX currently.
It only happened once.
I have had TMFX crash or indefinitely lock during development and extensive testing of OSC features several times. I have never found it to be reproducible. My suspect it was just too much i/o data while bumping the mark hard. It never happened to me while using OSC in a reasonable, real-live manner.
It happened on a large span of TMFX and macOS versions.
