Topic: Getting audio dropouts with UFX III on Mac OS?
I've been using a UFX III for the last 6 months or so and have been very pleased, but as of late I have had an issue where the audio stops working on the UFX III completely.
Audio is still playing in the OS (Logic, Safari, Max/MSP, VLC, etc...), but I hear nothing coming out of the UFX III. And if I check TotalMix, I don't see anything there.
Typically I have to manually switch over the device in the OS to something else (e.g. "Built-in" audio) and back, and then it works. As in, after doing this, I see audio in TotalMix and hear audio again.
Today, however, even doing that did not seem to fix the issue. I had to physically shut down the UFX III in order for it to work again.
I am on Firmware v20, Driver v3.31 on Mac OS 14.3.
Has anyone experienced anything like this?
2 (edited by rodrigo.constanzo 2024-02-10 12:03:39)
Re: Getting audio dropouts with UFX III on Mac OS?
For context here's a video of what I mean.
In this case I was able to get audio working again by switching away from the UFXIII and back again in system preference, but as I mentioned, I sometimes have to physically turn off the UFXIII for it to start working again.
https://www.youtube.com/watch?v=s3QqG3-dK5k
3 (edited by rodrigo.constanzo 2024-05-14 20:25:10)
Another follow up here. Following a suggestion from RME support I tried different input ports and got it working when using the following one:
https://imgur.com/a/h8g538g
I remember reading ages ago that on the laptops each side has different throughput/buses/etc... and basically weren't identical even though appearing that way. I guess the same is the case on the mac minis.
