Topic: MM mode and MC mode
I can se it easily can handle MM picup's, but what to do when using MC (Moving Magnet) .....
How will I benefit form using ADI-2 2/4 Pro SE with MC picups
I am using Fireface UFX III now,
will I benefit from buying an ADI-2 2/4 Pro SE and use MC, in connection with the Fireface UFX III ?
ore what to do, to get the best results ?
Thanks Jørgen
2 (edited by KaiS 2024-02-08 14:47:54)
Re: MM mode and MC mode
Rme4Jt wrote:
…How will I benefit form using ADI-2 2/4 Pro SE with MC picups
..will I benefit from buying an ADI-2 2/4 Pro SE and use MC, in connection with the Fireface UFX III ?
Just listening to a vinyl disc through my ADI-2/4 Pro SE.
The connected chain is absolutely high end:
• Sony PSX-800 Biotracer turntable.
• Dynavector Karat 17D MK II MC pickup.
• Ortofon T-30 step up transformer.
• ADI-2/4 Pro SE running a dedicated EQ for:
• Raal SR1a ribbon headphones / Jotunheim R.
Running the ADI-2 on 192 kHz leaves nothing to desire.
The digital RIAA preamp inside ADI-2 is superior to most analog solutions I’ve ever heard.
The key is:
Bypassing loads of analog electronics, usually needed for the RIAA EQ, pays off with an absolutely transparent sound.
Simply connect the ADI-2/4 Pro SE to the Fireface via AES, Optical or Coax digital.
