Topic: Fader Groups via ARC USB (without monitor assignments)
So I have managed to control a 5.1 hardware output configuration with a fader group activated via an ARC key, however this only seems to work when I have outs 1/2 (LR Front speakers) assigned to "main out" through the control room section.
Why is it that with outs 1/2 unassigned and routed manually I cannot activate and control a fader group with the encoder wheel?
The fader group still activates but the encoder wheel does not move the faders like I would expect.
I tried removing the default encoder function in the ARC menu, but the encoder still does not move the faders when the group is activated.
This is not a game-breaking issue, but it is rather mysterious to me as to why this is not allowed.
Am I doing something wrong here?
Re: Fader Groups via ARC USB (without monitor assignments)
The knob only controls the channels set to MAIN OUT, and any that are fader-grouped with it. If you do not want AN 1/2 as part of the speaker/fader group, then you only need to use the Assign button to change MAIN OUT to a different output pair that is in use (AN 3/4 for instance).
3 (edited by lyricalaloof 2024-03-06 04:39:10)
The fader group still activates but the encoder wheel does not move the faders like I would expect.dinosaur game
Removing encoder functionality is very difficult. You need to be more persistent.
