belnova wrote:Hi there, first time poster, longtime lurker.
I worked with a fireface uc for the past 15 years, served me well. But recently I upgraded my studio (pro acoustics) and speakers (barefoot microstack 45) significantly. I'm looking at upgrading the signal chain now and interested in the adi-2 product line (dac/pro). I do have a few questions i'm hoping someone here could point me in the right direction:
1- would the old UC be appropriate to still use as my main interface, sending it to the adi-2, or is it just completely outdated for the purpose / mismatched in quality/features?
2- if i can still keep the UC, what would be the optimal way to connect it to the adi-2?
3- would the adi-2 dac be sufficient for my needs, or do i need the pro fs? It's hard to distinguish the added benefit of the pro. I don't record, do everything ITB, main use is produce, mixing and mastering.
4- what would be the downsides of removing the UC completely and using an adi-2 (dac or pro) by itself as my main audio interface (for my use case of produce/mix/master but no recording)?
thanks so much in advance for your help!!
1- yes
2- using one of the digital I/O ports, best an optical port for getting galvanic isolation, see also my blog article
3- see my blog article
4- IMHO suboptimal, then you are missing TotalMix FX
Integration into your Setup:
https://www.tonstudio-forum.de/blog/Ent … our-Setup/
Models, Use Cases (all except ADI-2/4 Pro SE)
https://www.tonstudio-forum.de/blog/Ent … ses-EN-DE/
This document explains/summarizes a lot about the basic cool features of those devices, and most if not all the information about the ADI-2 Pro FS R BE is also applicable for the ADI-2/4 Pro SE.
With the ADI-2/4 Pro SE, you get additionally these features:
- more recent ESS DAC with even little lower converter latency
- 5 reference levels in combination with the feature Auto Ref Level, a broader range where SNR/Dynamic is being optimized
- if I remember exactly, more D/A filter
- an additional play out path for e.g. a mastering chain
- possibility to connect a turntable, usually MM but with additional preamp also MC cartridges
- new Pentaconn plug for connecting balanced headphones with this new plug type which became popular for this purpose
- a "trig out" port to trigger a device like e.g. power amp to turn on/off (if supported by such a device)
I would choose an ADI-2 Pro FS R BE, more flexibility. Maybe even ADI-2/4 Pro SE.
