Topic: UCX II - Issues with ASIO playback
I am using a UCX II for music playback in Windows. ASIO output in Foobar works flawlessly; however, I am experiencing severe distortion/bitcrushing in Qobuz and Audirvana either when the track sample rate changes or when certain apps are open (e.g., Chrome). This issue persists regardless of the buffer size.
LatencyMon reports no issues. I've tried using multiple USB ports with both cables included in the box, but without success.
My specs are: AMD Ryzen 5 7600X, Asus TUF Gaming B650-Plus, Windows 11 x64.
I would be grateful for any help in troubleshooting this.
Re: UCX II - Issues with ASIO playback
Some applications do not support change of sample rate. It's a programming issue on the application side.
We had this also with MusicBee in the past. I contacted the author some years ago, and he was so kind to spend some time on it and could successfully fix it.
Try MusicBee, and then you can use this as a reference how it should work, and then you should contact the companies of the audio player which do not work.
