1 (edited by cupakm 2024-02-21 21:47:44)
Topic: Updating FW on a QEMU/KVM-virtualized Windows 11 worked
Hi all,
anyone had the guts to try it?
For me it worked. Tried only my trusty old 1st-gen Babyface, which I don't really need at the moment, but it seems like the whole thing worked just fine - well at least redirecting physical USB device in KVM hypervisor config, the guest OS (non-activated Win11 for free) did recognize it, installed RME driver, FUT, TotalMix, DigiCheck... seemed fine before and after the update too, even TM popped up when I virtually plugged the USB in from host to guest. Didn't measure the latency, but that wasn't my point anyway, only updating firmware. On a non-virtualized Windows all seemed fine afterwards. Then back to CC on Linux I'm all happy too.
Was wondering if such a FW update worked for anyone else, possibly with non-USB devices.
2 (edited by 21hertz 2024-12-07 01:48:39)
Re: Updating FW on a QEMU/KVM-virtualized Windows 11 worked
Do you use USB pass-through for the RME interface to the Windows VM?
How does it work for low latency usage in a DAW?
Thinking of going Linux as base OS.
I would also run either VMware Workstation (since I also got USB audio interface it should be able to be pass-throughed).
Or KVM/QEMU.
Since I use Cubase I could run it inside a Windows VM if the low latency part works....
Yes.
Didn't measure, my point was only updating the firmware. Then I switched back to CC in Linux.
Hopefully. Please try and let us know.
4 (edited by gleeman 2025-02-20 15:55:21)
I tried with my UCX  II with KVM/QEMU with USB pass-through of the device, TotalMix works flawlessly and even the firmware update was successful, without bricking my device. With USB redirection it doesn't work.
I tried playing back a youtube video and the audio had no glitches. I'm not sure if one could use this for low latency audio, but at least for updating the firmware it's a viable solution.
Note: remember to unplug the USB cable, and set the device in CC mode OFF to upgrade the firmware, then plug the cable again
--> This guide <-- helped me a lot in setting up my VM
