Topic: Recording to DP not showing up
Trying to record analog from mic input 9. Not sure where this is outputting to in order to see it in Digital Performer. I have the input set to channel 9 on the DAW, and have tried scxrolling through all the inputs but it still doesn't register in the program. I can hear out coming out of channel 3-4 to speakers, but no signal reaching the channel I wish to record. Confusing. Any suggestions?
2 (edited by waedi 2024-02-23 00:22:09)
Re: Recording to DP not showing up
Hello Soundminds
In the DP settings : Audio input device RME is selected ?
Some DAWs have input device and output device separate selection.
If this is a Mac computer, also check MacOS system preferences Security&Privacy / Microphone : is Totalmix listed and enabled ?
Solved. Thanks waedi! The privacy microphone setting for DP was disabled.
Congratulations !
Glad you can work.
