oraya wrote:thanks for the quick answer and link!
I use Mac M2pro. Driver Type is CoreAudio
its a very powerful workstation which can handle big cpu pressure so I don't think there is any external plugin or factor causing the cpu to load latency...
my setup is:
Sample rate 48000
Buffer size 64 samples
I/ Latency 2.10 ms
O/ Latency 2.21 ms
Overall Latency 4.31ms
After reading in the link that rhe sample rate could improve the latency in recording, I tried to record at 96000 / 64 sample and metronome and it seems that it improved the latency a little... but it seems a lot to record at this rate when I will be loading many tracks, plug ins ecc....
Converter Latency is much lower compared to the latency over USB/FW/TB. Nowadays, near zero.
Look at the manual, there is no merit in using double+ speed to optimize latency only for a tenth of a millisecond, right?
Using a lower ASIO buffer size reduces latency much more, see my table in the posting above.
Regarding the use of double/quad speed, you should be aware of the following:
If I remember right, there are some VSTi which do not support double/quad speed because sample libs are missing for that speed.
You put more load on your system (double amount of data to process everywhere).
If you are working with external devices which are connected via ADAT, you have only half of the port capacity at double speed and only a quarter if you worked with quad speed (which is IMHO nonsense anyway). The port multiplexing does not happen with analog ports on your system or those which are 2ch based anyway (AES, SPDIF).
Tip: Check / Optimize your monitoring whether you route over DAW. Better route locally on the recording interface.
To show you how low latencies are, I made the following calculation comparing UFX+ to UFX III.
When playing music life on stage, you have to deal with longer latencies.
9 samples difference in converter latency is only 6.7 cm (audio transmitted through the air)
20 samples difference in converter latency is only 15.4 cm (audio transmitted through the air)
