1 (edited by vic.bit 2024-02-26 21:41:26)
Topic: FF 400, Total mix only send L to hw outputs
Hi! I have a FF400 running in a macbook pro with a M1 pro, and Ventura. My beloved Fireface is the oldest equipment of my studio and some outputs sounds bad (low volume or digital noise) but now i´m facing a strange problem. The 1/2 software playback only send the L channel in total Mix.
Here is a pic of Total mix
https://www.dropbox.com/scl/fi/kt7gxeh5 … z&dl=0
Re: FF 400, Total mix only send L to hw outputs
Hi
I would try
- full reset of Totalmix
- check firmware and driver versions, maybe update
Thanks, I have tried a reinstall with no luck. The firmware and driver versions are the latest. I will try an old macbook to confirm if there is a hardware problem. it would be strange but who knows..
Since you already had issues earlier (low volume and digital noise), maybe there really is something wrong with the Fireface - sadly.
