Topic: FIREFACE + ABLETON + M1 = Latency
Hi all, I dont know if you have been having latency problems, but I'm getting huge latency with my FIREFACE UCX, I have the most powerful MacBook M1 from year 2023, and the latency is at 11.8 ms, with a 256 buffer,and  zero plugins in my session not even ableton plugin, 48 khz sample rate, its crazy and impossible to use like this... what is wrong with RME? I have been an RME client 12 years, and I have had lots of problems since I changed from my old babyface and old mac book to a new FIREFACE with a super powerful computer... can someone please help me to solve this issue?
2 (edited by waedi 2024-03-04 03:10:01)
Re: FIREFACE + ABLETON + M1 = Latency
You could sort out Ableton with a simple test with another DAW, try Reaper for a test, it's for free.
And without interface connected only internal loudspeakers of the Macbook, how is Ableton performing then ?
And did you try with other buffer size ? Try 64 and 32.
3 (edited by maggie33 2024-03-04 04:02:38)
Drivers installed?
Here with a 802 with AL and a M1:
6.3 ms I/O @48kHz @256 Samples
3.5 ms I/O @48kHz @128 Samples
2.8 ms I/O @48kHz @64 Samples
1.9 ms I/O @48kHz @32 Samples
whats wrong with you (or your setup)?
Edit:
BTW: Not possible. In 2023 the lowest Macbooks were equipped with a M2...
“Do It For Her”
4 (edited by oli77sch 2024-03-04 10:08:02)
enriquecbarcena wrote:
… new FIREFACE with a super powerful computer... can someone please help me to solve this issue?
Can you please share
- macOS version
- RME driver and UCX firmware versions
EDIT: I just checked the numbers on my system:
- Mac mini M1 2020, 16GB RAM, macOS 14.3.1, Logic pro 10.8.1
- RME Babyface pro, DK driver v4.10, firmware v206
At 48kHz it shows me
@32 = 3.1ms
@64 = 4.4ms
@128 = 7.1ms
@256 = 12.4ms
Are you using your UCX through a Mac Aggregate device, or connecting directly?
Apple Mac Studio Max 64gb RAM, Ventura, RME UFX III, 12Mic, Pulse 16 MX, Studio One 6
anyhow... the latency presented in DAWs (and calculated by coreaudio) is more roundabout than a real value, you can proof.
There are so much factors, which affect this...
And the latency-thing has already been discussed in many threads... If you want to get a real latency - you have to use the RTL Utility.
MC explained it in other threads with details.
“Do It For Her”
Not meant to disagree, but I once measured the values on my system from above (post nr.4): they were very (!) close to the values I could read in the Logic audio settings window, in most cases exactly the same!
8 (edited by ramses 2024-03-05 08:19:58)
Maybe to add: the latencies in the driver match only with analog I/O ports on an interface.
Only there the vendor knows the latency values for the converters.
The driver tells the input and output latency to the DAW.
If this is coded properly into the driver, then these are the same values
that you can measure with RTL utility in a loopback test.
In the past years, I heard rumors about, that not every vendor does is so exact like RME.
For the RME recording interfaces that I owned, it always matched (UFX+, UFX III). Before, I didn't measure it.
This is for Windows with ASIO = direct access to the HW.
With Apple, it might be slightly different because there you have to go through the Apple driver additionally.
I am not sure whether it is fully predictable how much latency this causes (depending on the CPU),
thinking here about the additional safety buffer that I noticed in the chapter latency.
