Topic: Inputs/Outputs Mac vs PC
Asking simply, since a lot of details could go into this.
On PC I can see my inputs/outputs for my RME interfaces in all of my typical Audio Software.
With the same gear on a Mac I cannot. Is there a trick or an oversite I am making?
My most important example is Zoom. On PC I can choose any input/output for the Microphone or Speaker selection in Zoom preferences. On Mac I can only generically select BabyFacePro for example.
A secondary example would be Reaper. I can select the exact master output I need in Preferences on PC, on Mac I cannot.
I have Mac students with RME, some I encouraged the purchase, but I can't come close to the complex routing that I can do on PC.
Thanks for reading and for your time.
Re: Inputs/Outputs Mac vs PC
You are correct about Zoom, this is a limitation in their app where only Input 1/2 and Output 1/2 are accessed.
Reaper, however, does not have that issue. You can directly choose any I/O you like.
See here: https://www.youtube.com/watch?v=Hh04XZqFsic
OK. Thank you, Jeff.
