Topic: Expanding the UCX / Babyface
I've had an RME UCX for many years and recently replaced it with the UFX III, intending to use my UCX as a mobile recording rig interface.
The thing is, that the UCX has only 2 mic inputs, and my remote recordings often include 3 to 4 mics. I know the UCX can be expanded via ADAT, but buying another big rig with 4/8 more inputs via ADAT feels like a bit of an overkill to the small setup I have in mind.
So I was wondering - is it possible to somehow use the line inputs (Ins 3 and 4) on the UCX as mic inputs? The inputs already have preamps on the RME, but are just the wrong shape.. (TRS instead of XLR).
Thanks all,
Daniel
PS same question applied to the Babyface, which I believe also has the same 1-4 input layout.
2 (edited by vinark 2024-03-19 16:17:20)
Re: Expanding the UCX / Babyface
If you buy mic preamps then yes. They are available for all budgets and all sizes.
Like this one https://www.bax-shop.nl/voorversterker/ … versterker
You can also expand less expensive by using this RME product and connect it using analog cables.
https://rme-audio.de/de_quadmic-ii.html
https://www.thomann.de/de/rme_quadmic_ii.htm
4 (edited by oli77sch 2024-03-19 19:32:16)
No, there aren’t mic preamps on inputs 3/4 of UCX and Babyface. These are line inputs which also work for instruments, but not for microphones.
