D-Notes wrote:Hi Everybody, I am leaning heavily towards buying the Babyface Pro FS to upgrade my setup. One thing I would like to know is there a way to load Autotune in TotalMix FX to print or monitor on vocal recordings. I appreciate anyone that can help clear this up. Looking forward to becoming an official RME user.
TotalMix FX is for controlling the FPGA/DSP on the interfaces.
For optimum user experience and stability, the application focuses on that.
3rd party plugins (VST/VSTi) are the number one reason for instabilities in DAW's.
Those instabilities are not wanted in TotalMix FX, therefore this design decision.
But this is no problem, you can use VST and VSTi at any time in your DAW as send or insert. Or you can even use external effects and use them in TotalMix FX or define them as VST in the DAW and use them as insert and sent.
There are also a few recording interfaces available with FX. But you have only one effect bus where you can add exactly those FX to monitoring mixes. The Babyface Pro FS with partial implementation, part of FX is rendered on the PC. This is required, otherwise this interface could not be operated bus-powered (has an optional PSU).
The other interfaces that offer this have a dedicated FPGA for that (UCX II, 802 FS, UFX II, UFX III). The only PCIe card with FX chip is the HDSPe MADI FX.
Babyface Pro FS is an excellent interface. If your budget allows, the UCX II would give you a lot more possibilities.
For an overview of RME interfaces (excluded PCI/PCIe based interfaces) and capabilities, you can use my Excel comparison sheet, which puts together a lot of details. https://forum.rme-audio.de/viewtopic.php?id=35156
