1 (edited by GMB 2024-03-21 16:56:16)
Topic: NOOB to Room EQ - measured using REW - what next?
Been looking around and haven't seen a basic description of how to use the results of REW in TotalMix.
I did an L, R, and L+R analysis - I think I did it correctly.  But no idea what to do next.
There are a lot of tutorials for REW.   But nothing for using the results in RME.
Also, I did not do the loopback test in REW.  I'm assuming the RME's response is probably pretty flat -- am I wrong and this is an important step?
Thx
(Fireface UFX+, Mac Sonoma, Genelec 1030A)
UFX+, Reaper, Ableton, Mac, Drummer, Modular, Norns/PiSound/Organelle....
Re: NOOB to Room EQ - measured using REW - what next?
You need to process the result with a 9-band PEQ for export. This is not found as fixed preset, use the Configurable EQ to set up one.
https://www.roomeqwizard.com/help/help_ … liser.html
https://www.roomeqwizard.com/help/help_ … indow.html
The result is a text file that allows you to manually enter the values into the Room EQ panel.
3 (edited by GMB 2024-03-22 04:13:18)
Yikes.
I see Generic & Configurable PEQ options on the EQ screen.  Do I just change the # of filters to 9?  (pretty much just guessing at this point!). Do I need to recalculate the band widths?
Also I assume my target should be Full Range Speaker as I don't have a sub?  And no idea if I need to set anything else like room dimensions.
Here a video which you can use with REW and Room EQ: https://www.youtube.com/watch?v=DGrkeE- … bHRlcnM%3D
Audio AG Support
Thx - I duplicated the steps in the video.  But the end result is a wav file.
How do I get values I can import into TotalMix that are divided into 9 bands?
Just bumping this - I followed the steps and created the correction EQ file from REW, but it's just a wav.
Is there a way to get text values from REW or the Wav file that I can import or manually add to TotalMix' Room EQ?
Thx!
