Topic: [Solved] Help with Digiface Dante install - Mac Sonoma
Hi there,
Has anyone successfully got their Digiface Dante working under Sonoma 14.2.1?
I followed the instructions on the website for downloading correct drivers, authorizing under security prefs, etc....but still no luck.  Total Mix launches, but doesn't see the interface.  I'm also a bit confused as the driver at the top of the list recommended for this, comes up as Fireface USB DK 410?
I'd be grateful if anyone has any suggestions.
thanks, Michael
www.indre.com
mc@indre.com
Re: [Solved] Help with Digiface Dante install - Mac Sonoma
The driver archive comes with a readme and clear instructions how to install, in the begining and at the end of the document. That readme also lists the DF Dante as supported together with 16 other devices.
That said - 'authorizing under security prefs' - does that mean you allowed the RME driver during installation in Security & Privacy? If TM FX does not open this is typically missing.
Matthias,
Thanks for your reply.  I was able to get it going today.  It turns out that I needed to use the external power supply.  Maybe the USB bus power wasn't enough to bring the unit up to spec.
-Michael
