Topic: [Solved] ADI-2 Series Remote for iPad not connecting
Tried searching and couldn’t find an answer.
I’ve downloaded the Remote for iPad app.
How do I connect the iPad to the ADI-2 DAC FS to use the app?
I tried using a Lightning to USB 3 Camera Adapter and connected the USB from the DAC to the adapter but it didn’t work.
Re: [Solved] ADI-2 Series Remote for iPad not connecting
The DAC needs to be updated to the latest firmware version, for compatibility. Connect to a Mac or Windows system and run the RME Flash Update Tool for the unit. You can get that app on the Drivers tab from the product page.
https://rme-audio.de/adi-2-dac.html
Thanks, I did update the firmware, that was one of the first things I did. How does the iPad see/connect to the DAC after the f/w update?
Audio - automatically. Remote - via internal MIDI. Check that MIDI Control under SETUP - Options - Remap Keys / Diag is set to ON:
The answer to your question is: the device needs to be connected via USB to the iPad, as described in the app notes in the App Store.
6
He said he tried that in his first post.
Thank you, I did not have it set to ON.
I'm now able to connect via my iPad (VERY NICE!).
I appreciate the help.
