Topic: Update went horribly wrong - ADI-2 Pro FS R Black Edition
All
tried this morning to update my ADI-2. The first attempt failed with programming status failed 80000000/5. I powerd-off the device and rebooted. I tried again with the same result. After a second power-off and reboot, I selected to 'Flash all'. The process started and did not finished. After the power-off, the devive does not start anymore. The power-button LED becomes red, when powering-on. By switching the device on, the LED changes to white, but no relais clicks and the dsiaply remains black. USB port ist not reachable anymore. Reseeting the device (press encoder 1 and encoder 2 and the VOL key) does not work.
The versions installed were: USB: 265, DSP: 127
Any help?
Stefan
