KaiS wrote:Why not just fix the internal power supply?
If you‘re capable to built a new multi-voltage linear PSU, you should be able to find the faulty electronic part and replace it.
Trace the DC voltage and see where it‘s lost, this is about where the fault sits.
If you‘re out for help you should mention the exact model of ADI-2, there are 4 different models and several versions of each.
BTW:
I don‘t know and can’t find a “V-Test Plugin” but a cheapo $20 multimeter is the only tool needed for this kind of fault-finding.
My own adi-2 is ak4490, version 3V2.
I'll use the picture from internet to explain, thx.
Without schematic, it's hard to figure out for my poor ability.
I burn the tvs diode, and it got dead to short the Vin and Gnd.
So I replace it, but it still got no 3.3v.
I'm not sure anything else burn?
tps54294(left and bottom corner) should convert Vin to 3.3v,
when I push the red button, pin 12(en2) got 3.3v, but still no 3.3v from pin14(sw2)
According the datasheet, it used10v to enable, I'm not sure what's wrong, or is 3.3v enough to enable the DCDC converter?
pin 5(en1) seems to connect to 3.3v, so no voltage out from pin3(sw1).
And tps55340(left and up corner) may convert Vin to +16V, -16V.
But I don't know how to enable it.
The V-test pulg-in just near by TI's DSP.
It seems easier to using power from outside, with schematic.
For me, it's really hard to trace.
Or could someone help, please send me schematic in P.M.
Thx for the help and bother.
