1 (edited by olaf.kahlen 2024-04-01 14:29:40)
Topic: ADI-2 DAC fs - problems by dropouts and ringing in high frequency
my DAC makes problems when it is warm, it has sound dropouts and ringing in higher frequency ranges, the problems occur sporadically. Is there a solution to the problem?
PS: Furthermore, the power connection causes difficulties from time to time due to lack of contact....
2 (edited by KaiS 2024-04-01 17:54:16)
Re: ADI-2 DAC fs - problems by dropouts and ringing in high frequency
Both seems to be hardware faults that might boil down to a single one.
Try a different PSU if you have:
9-15 Volt 10W (~1A), Center Pin + / positive..
If that doesn’t help, send ADI-2 DAC in for repair.
3
olaf.kahlen wrote:
Sounds like the famous 'I did not notice the ps connector can be locked - after it was inserted deeeeep into the socket'.
