Topic: USB input for UFX+
What is a good USB to SPDIF converter for input to the UFX+?
My use case is a home audio system with network audio and digital room correction.
Network streamer > USB > ADI-2 pro fs be > SPDIF > UFX+ > Windows pc convolver > UFX+ DA and analog output (4 channels)
I use Digital Room Correction software that needs the measurement mic to be on the same AD hardware as the DAC, so  the UFX+ works well to provide AD and DA roles.
The ADI-2 works well as a USB converter, but most of its functions are overlooked. I would like to replace the ADI-2 in its role as USB to SPDIF converter. I will then use it for a headphone amp and for other DAC duties.
What would you recommend?
UFX+; MADIfaceUSB; Startech active USB3 cable; Sonnet Allegro Pro adapter; Win11x64
2 (edited by ramses 2024-04-05 09:49:40)
Re: USB input for UFX+
What network streamer do you have?
Does it have other digital outputs which you could use to connect it directly to the UFX+?
Just brainstorming, would any of these two setups support your use case?
Option1: Network streamer connected via SPDIF to UFX+
PC--------------USB2--------------------------+
|                                                              | USB2 for remote control + fw update
|USB3                                                      | ADI-2 Pro in AD/DA mode
UFX+--ADAT1 OUT----------->ADAT IN---ADI-2 Pro--3/4--Active Monitors
   \        \--1/2--Headphones
     \---ADAT2 IN<-------------Opt SPDIF---Network Streamer ???
Option2: several devices connected to ADI-2 Pro via TOSLINK switcher
TOSLINK Switcher in Front of ADI-2 Pro where you can select up to 4 ADAT/opt. SPDIF sources:
PC--------------USB2-------------------------------------------------------------------------+
UFX+--ADAT1 OUT------------>IN1---Optosel 4:1---ADAT OUT----->ADAT IN---ADI-2 Pro--3/4--Active Monitors
           Network Streamer-->IN2---/        \--1/2--Headphones
           TV?--------------------->IN3---/
           BluRay Player?------>IN4--/
Ramses
Your reply helped me to more clearly understand my wiring and options.
The key issue is getting a USB source to feed the UFX+. My current setup uses the ADI-2 pro fs be in USB mode to do this. It works.
CURRENT SETUP
Desktop                                               Hifi Corner
PC (Daphile as network streamer)
USB3
ADI-2 --------- Opt SPDIF out -------- UFX+ opt2 in
    |     --------- Opt SPDIF in --------- UFX+ opt2 out (SPDIF)
Headphones                                             USB3 (out/in)
        Windows PC
        (Audio convolver)
The Daphile digital audio USB output is converted to SPDIF by the ADI-2 and sent by optical SPDIF to the UFX+. The UFX+ returns digital audio by optical SPDIF to the ADI-2 for headphone listening post-processing. Or, the original digital USB source can be listened to on headphones. Routing is in TotalMix FX.
Clock Source is set to UFX+ so that the measurement mic ADC and DAC clock are the same. This is necessary for digital signal processing in the Windows PC by Acourate (Audiovero.de).
For ADI-2 FW updates, I disconnect the USB from the Daphile PC and connect to the Windows PC.
I tried 2 alternative setups that I own already to feed USB to the UFX+. They did not work.
Conclusion: I will keep my current setup.
That said, I am interested in changes you might suggest, if any.
Thanks again
Labdoc
