Back to the topic.
First, it is important to understand your setup and the concrete issues.
Regarding your 1st posting I was mislead by you stating Digiface USB and UFX would use the same driver [model].
But this is not the case, see also my posting #7. How did you came to this statement?
anvilmusic wrote:I have a Digiface USB and UFX 1 which both use the same driver model, and thus whenever I connect them both to my windows PC they combine under the same "Fireface ASIO" driver.
This can't be the case.
UFX and Digiface USB are using two different ASIO drivers
— UFX the older USB driver
— Digiface USB the newer MADIface driver
So you already have the situation to run the two interfaces with two different drivers.
But then I am really wondering, how you set it up and how you use it from application / driver perspective.
Your setup and use cases are absolutely not clear to me.
anvilmusic wrote:Unfortunately, this causes my DAW application launches, sample rate changes and other operations to lag a lot
Sounds very unusual to me. Especially the part with the laggyness.
So, can you please provide more details about your setup?
Also about your PC and about any special use cases that you might have?
Regarding lag. Please some numbers to get a concrete understanding of your situation.
Which application, what time to start up the application with one, the other or both interfaces.
Please note: there are interfaces with a lot more I/O ports than your UFX and Digiface USB.
Some time ago, I had two UFX+ and an ADI-2 Pro connected to my PC without any such issues.
Your setup (UFX and Digiface USB) has 126 ports in total, mine had at that time over 380 in total.
And with the ASIO driver, all channels are instantly transferred, no matter whether used or not by the application.
I also didn't understand what issues you have with sample rate changes.
Can you please detail your setup / use case to make this clear?
anvilmusic wrote:[...] and I would actually prefer to keep the two interfaces separate.
Using one for audio application A and the other for B.
What is your use case for that?
