Topic: Zoom sessions not working bit rate other than 96K. UFX+, MBP M1.
My Zoom setting is done with mic via 48v, loopback from AN 1/2 out on UFX+.  When I set bitrate to 48k or 44.1K, zoom shows error message saying that the speaker does not work.  Unless I change the bitrate to 96K, it does not start video or audio sessions.  When bitrate is 96K, zoom works well.  My DAW, notation software is set as 48K, so, I need to solve this problem to share daw sessions via zoom for music classes.
My clock is set to internal.  I tested with original sound for musicians, high-fidelity and echo cancellation, etc with no avail.  I use Ferrofish Pulse 16 via MADI also that is set at 48K.
Any idea why this happens?
Re: Zoom sessions not working bit rate other than 96K. UFX+, MBP M1.
A screenshot of the Madiface Settings Dialog would be helpful.
3
Yep. How many WDM devices active? WDM sample rate is 48 kHz?
I don't know what WDM is.  I don't see that option on my RME Thunderbolt settings.  I am attaching picture of total mix and RME thunderbolt settings, and also Ferrofish settings and zoom error message.  I use Mac OS 14.4.1.  My main speaker output are through AES to GENELEC 2 channels.  I don't think GENELEC has any bitrate setup by itself.  I use AN 1/2 output only as loopback only zoom conferences.  I see MADI 96KHz frame on and off option in Ferrofish, tried both, it does not affect.  Zoom still crashing.
[img]Screenshot 2024-04-07 at 9.54.31AM[/img]
[img]Screenshot 2024-04-07 at 10.02.33AM[/img]
[img]Screenshot 2024-04-07 at 10.04.34AM[/img]
How do I attach images here?  I tried to drag and drop in this box and in between .  It did not work.
WDM is only applicable for windows, but as you didn't tell your OS it was just a guess.
How to attach images? Place image to cloud and link here using URL or IMG tags, see here:
https://www.tonstudio-forum.de/blog/Ent … rum-EN-DE/
BR Ramses - UFX III, ADI-2 Pro FS R BE, M-1620 Pro D, 12Mic, XTC, RayDAT, Win10, X10SRi-F, E5-1680v4
Are you changing sample rate in Audio/MIDI manager?
_____________________
Eric Seaberg • San Diego, CA • USA
A.E.S. • S.M.P.T.E. • S.P.A.R.S. • I.E.E.E.
I found that in Audio Midi setting Zoom was setup at 96K.  I changed it to 48K, but still same error message happens.  Rebooted couple of times with no difference.
https://bywoundcareinternalmedicine.box.com/s/9t6marouex4rao5jeop1yzl94cjnfqdg
https://bywoundcareinternalmedicine.box.com/s/x6p3qb74kpyt5kg23uxqfepqas7rac0e
https://bywoundcareinternalmedicine.box.com/s/yvakznfhnd2p9t2qvz968ri9160jp6l1
8
We have user feedback that using the USB Kernel Extension driver solves that issue. If the same can be said for Thunderbolt is unknown. Note that this is most likely a known limitation of Zoom, not being able to handle an audio interface with so many channels. This software is designed for headsets...
I used to use Kernel Extension driver, then changed it to Driver Kit driver last summer when I started using Dorico Pro.  Dorico caused audio engine problem with Kernel Extension Driver that time.  I will try to use recent version of Kernel Extension Driver, and will let you know the results.  I remember that I did not have bit rate issue that time using Ableton with Zoom at 48 kHz.  I will update after trying Kernel driver.  Thank you.
I updated the driver to Kernel Extension Driver.  Now Zoom issue is solved finally.  Please in future driver update, fix this issue with driver kit driver.  Thank you.
