1 (edited by benjaminstelzer 2024-04-12 16:01:13)
Topic: Firceface UC -> not able to select as Windows 11 device anymore
Hello everyone,
I had to do a fresh install on my main PC after a Motherboard switch.
I installed the latest version of Windows 11.
The problem is: While I can see the RME Fireface UC in the Device Manager as Audio Controller and can use TotalMix, it's not possible to select the device in Windows. It's simply not available as playback device. (I also checked if it's in PC mode, and it is)
The device works fine on an older PC.
Any idea?
Re: Firceface UC -> not able to select as Windows 11 device anymore
Ah, WDM devices was somehow set to zero! Setting it to one fixed it!
