Topic: MIDI note off F#2...C#3 sets AN 1/2 Volume to 0Db
I am using MIDI controller to control main and phone volume for Babyface Pro Fs, as well as gains for the hardware inputs. Everything works fine but if I press any of F#2 ... C#3 on my controller then my main volume jumps to 0db. It looks like it's triggered when the note is off.
Could you tell how to fix that? Essentially, I would like to control totalmix with CC commands only. Thank you!
Re: MIDI note off F#2...C#3 sets AN 1/2 Volume to 0Db
Disable the Protocol support in TM FX Settings - MIDI tab.
Thank you MC, that worked.
