Topic: Learning about RME
I’m just trying to understand what RME offers…
If I own a Fireface UCX II, why would I need an ADI 2/4? In my understanding the Fireface has AD/DA converters too and I don’t need the phono preamp.
Thank you,
Serge
2 (edited by ramses 2024-04-20 14:01:30)
Re: Learning about RME
Read the manual of the ADI-2/4 Pro SE, then you know it feature-wise.
   https://rme-audio.de/downloads/adi24pro_d.pdf
   https://rme-audio.de/downloads/adi24pro_e.pdf
Furthermore, a good source of information, my blog article here which collects some interesting information.
https://www.tonstudio-forum.de/blog/Ent … ses-EN-DE/
You should also watch the YouTube video about the converter shootout, ADI-2 Pro FS (older model) vs Lavry and HEDD.
An alternative might be the ADI-2 Pro FS R BE
   https://rme-audio.de/downloads/adi2profsr_d.pdf
   https://rme-audio.de/downloads/adi2profsr_e.pdf
Major differences between ADI-2 Pro FS R BE and ADI-2/4 Pro SE see this sticky posting:
https://forum.rme-audio.de/viewtopic.php?id=32506
What you get additionally by the ADI-2/4 Pro SE (not only phono input):
  • 5 ref levels keep SNR/DR high over an even longer range
  • 4x Line Output (XLR and TRS); 2nd rear output now balanced (TRS)
  • TRS output can be assigned to channels 3/4 as independent 2nd line output
  • Balanced headphones use channels 3/4 only
  • Single standard 4.4 mm Pentaconn plug for balanced headphones, super low noise.
  • Headphone amplifiers with little more power (4W balanced) including IEM power setting
  • Line/Phono inputs (MM compatible) with RIAA mode "for directly digitizing vinyl discs"
  • Trigger out function for powering on/off external devices together with ADI-2/4
  • Supported D/A Filter (7): SD Sharp, SD Slow, Sharp, Slow, SD LD, Brickwall, NOS
  • New PSU ATS040T-P120, lockable, with safety ground
Optional (soon): linear power-supply from RME for all ADI-2 Series devices.
An additional plus for all devices of the ADI-2 series of devices, the ADI-2 Remote software.
   https://rme-audio.de/downloads/adi2remote_d.pdf
   https://rme-audio.de/downloads/adi2remote_e.pdf
How to integrate the device into your environment, e.g., to enhance your monitoring, see this blog article:
https://www.tonstudio-forum.de/blog/Ent … our-Setup/
I am using two ADI-2 Pro FS R BE in combination with UFX III.
One for the Recording and one for the HiFi corner.
What I really like are the benefits in sound and the features like dynamic loudness and auto ref level
which are very uniq features and are a game changer.
Furthermore, features like ramp-up of volume when plugging phones or switching between active monitors and headphones make the environment better operable also in terms of safeness for ears and equipment.
Different D/A filter can lead to a little improvement of the localization like percussive musical instruments like shakers, KaiS wrote to that topic.
3 (edited by Serge.Nelissen 2024-04-22 18:30:44)
RTFM! :-) :-) :-)
Serge
