bobkatz wrote: …In my case I'm stuck between a rock and a hard place as the headphone amplifier I am building will either go into clipping at -3 dBr in one reference case or produce significantly lower output in another reference case. Unless I build a 3 dB or greater attenuator.
A volume dial headroom of 3 dB exists in ADI-2.
Clipping takes place at +3.5 dB volume setting only (for a 0 dBFS input signal).
This extra range can be used to set a fitting ref. level.
The headroom is kind of meant to handle ISPs (Inter Sample Peaks), but the way I understand your style of working those don’t occur at yours.
bobkatz wrote:…I would like to make another feature request where a user can calibrate dBr to their own preference, for example, 0 dBr ----> 83 dB SPL with -20 dBFS pink noise or some other reference.
Why not just ask for integration of the K-System?
RME already has it built into DigiCheck.
bobkatz wrote:…To be honest, I would be annoyed by 6 dB jumps in volume at certain positions of the dBr control, which is the behavior of auto ref. I would be interested in hearing anyone's opinion if there is any PRACTICAL advantage to the auto ref. MC's intention was to offer an optimized SNR at any of the reference levels, which is exemplary, but admitting that the SNR is so good already that any of these settings are likely to produce imperceptible noise.
There are no level jumps in Auto Ref Level, check it out.
Analog switching and digital volume control work hand in hand for a continuous volume control in steps of 0.5 dB.
This way SNR and resolution is kept relatively constant (within 5.5 dB) over a volume dial range of ca. 23 dB.
Interestingly ADI-2’s digital volume control does not produce the expected artifacts like THD, see manual page 65, 66.
This makes it superior to traditional potentiometer controls which can cause significant distortions, even the best.
(Not to mention the gain staging problems that analog level control causes in amp design).
Using ADI-2 as a frontend can significantly lower the necessary analog gain of a power/headphone amp.
ADI-2 DAC’s full scale output is +22 dBu.
A STAX headphone can take up to ca. 54 dBu (400 V RMS, 1100 V p-p).
So just 54 – 22 = 32 dB of gain is necessary in the eStat amp.
bobkatz wrote:…Sounds interesting. Thanks. I will try that. Hopefully without blowing my ears out as I experiment!
If in doubt something could go wrong, I place ‘phones behind my ears.
