Keep in mind that a Ferrofish has 16 analog ports.
The BBF Pro FS has only 1x ADAT I/O, so you can use only 8 of the 16 ports at single speed.
At higher sample rates, even less due to the usual port multiplexing:
- 8 of its 16 ports @single speed (44.1/48 kHz)
- 4 of its 16 ports @double speed (88.2/96 kHz)
IMHO not really needed, but for completeness:
- 2 of its 16 analog ports @quad speed (176.4/192 kHz)
Therefore, the Ferrofish has 4x ADAT I/O to support up to double speed for its 16 analog ports.
There are two RME products which support 4x ADAT I/O: Digiface USB and RayDAT (PCIe).
The RayDAT offers a lot of useful I/O but is a complete digital card without any analog ports or mic preamps.
For the moment, you can also use the BBF Pro, but then only 8ch @single speed.
While we are at it, an alternative is to use MADI. RME has different products to support MADI (USB and PCIe based), but it would cost more compared to the other solutions.
