Topic: Madi and AES together
Hi. I got the MADIFace USB to connect my console to the computer, but I would like the connect my Lexicon 960L as well.
It has AES/EBU so my question is: Can I use the HDSPe AES card together with my Madiface USB?
Best Regards David
Re: Madi and AES together
On a Mac you can use the HDSPe AES card and the MADIface USB in a aggregated device. You can clock the MADIface with Wordclock on the BNC IN.
On Windows it's more complicated, because they use different drivers.
You can also use a converter like the RME ADI-192 or the ADI-8 QS with MADI option card, if you can find them.
The ADI-6432 is bit of an overkill but it is still available.
Audio AG Support
Can i use the Digiface USB (adat) together with my Digidesign 192 and get AES/EBU that way and still run the Madiface USB?
