1 (edited by soupiraille 2024-05-23 09:24:21)
Topic: (Solved) [AIO Pro] Not able to set buffer to 8192 @ 192kHz
Hi there,
On Windows, I am not able to set the buffer size to 8192 @ 192kHz, the highest in the list is 4096. Is that normal?
At that sample rate, 8192 is supposed to be available.
I have latest firmware (23) and drivers (4.47).
Thank you!
Re: (Solved) [AIO Pro] Not able to set buffer to 8192 @ 192kHz
In the settings the number of WDM device is what ?
Try zero for a test.
I had one WDM device. I tried with 0 WDM device and it's the same: 8192 isn't in the buffer list.
Thanks for the help.
soupiraille wrote:
Hi there,
Thank you!
If it is not in the list it is not supported by the driver. So it's normal.
Audio AG Support
5
And that is true for all sample rates. The line with 8192 in the manual is a leftover of older manuals. The HDSPe series driver does not offer 8192 anymore, since 15 years or so.
Thank you.
