Topic: RME M-32 DA Volume Control
Is there any way to control the channel level output of the M-32 DA with a physical controller, such as MIDI? I know you can send MIDI messages to control the amplitude, but that would require software to translate a MIDI fader to the correct SysEx format. Is there something "out of the box" that can control the output level of all channels?
Re: RME M-32 DA Volume Control
straight forward solution :
[Edit Mod]: obviously misses the point.
This is only 2 channels though. I need volume control for all 32 channels with a single knob or slider.
4 (edited by ramses 2024-06-06 21:11:30)
Perhaps a fader group in TotalMix FX and the assign one of the output channels to "Main Out" and control volume via ARC USB?
Store that in a dedicated snapshot for this purpose ...
5
The M-32 series does not support volume control via MIDI, so your statement is unclear.
In case you use an RME audio interface see Ramses' reply.
