Who Kan Mono wrote:Hello to all users of RME products!
I am in the trial period with this DAC and I would like to know if Babyface Pro FS or ADI-2 Pro FS are even better than ADI-2 DAC FS not only from the point of view of DAC quality but also of headphone outputs.
Didn't you see that Babyface Pro FS is optimized for mobile use and works USB bus powered?
The headphone outputs of BBF Pro FS are "sufficient", but because of mobility/USB2 bus power
on the weaker side of the RME product line.
The details you can look up yourself in the technical section of the manuals of the particular products.
The Extreme Power Outputs of ADI-2 DAC/Pro FS and ADI-2/4 Pro FS are much (!) more powerful.
To put a few examples ..
Babyface Pro FS:
Output: 3.5 mm TRS jack, unbalanced
Output impedance: 0.1 Ohm
Output level at 0 dBFS, 1 kOhm load: +7 dBu
Signal to Noise ratio (SNR): 114.8 dB RMS unweighted, 118 dBA
Max power @ 0.1% THD: 90 mW
UFX III
Output impedance: 2 Ohm
Maximum output level at 0 dBFS, High: +19 dBu
Signal to Noise ratio (SNR) @ High: 116.5 dB (AES17), 118.5 dBA
Max power per channel @ 32 Ohm load, 0.02% THD: 200 mW (2.5 Vrms, +10 dBu)
ADI-2 DAC FS:
- Output impedance: 0.1 Ohm
- Output level at 0 dBFS, High Power, load 100 Ohm or up: +22 dBu (10 V)
- Signal to Noise ratio (SNR) @ +22 dBu: 120 dB RMS unweighted, 123 dBA
- THD @ +18 dBu, 32 Ohm load, 1.2 Watt: -120 dB, 0.0001 %
- Max power @ 0.001% THD: 1.5 W per channel
ADI-2 Pro FS R BE:
- Output: 6.3 mm TRS jack, unbalanced, stereo
- Output level at 0 dBFS, Ref Level +19 dBu, load 100 Ohm or up: +22 dBu (10 V)
- THD @ +18 dBu, 32 Ohm load, 1.2 Watt: -110 dB, 0.0003 %
- THD+N @ + 18 dBu, 32 Ohm load: -107 dB, 0.00045 %
Balanced Phones mode, as before, but:
- Output levels at 0 dBFS: Hi-Power off +13 dBu (3.46 V), Hi-Power On +28 dBu (19.5 V)
- Output impedance: 0.2 Ohm
- Signal to Noise ratio (SNR) @ +28 dBu: 123 dB RMS unweighted, 126 dBA
- Output level at 0 dBFS, Hi-Power On, load 150 Ohm or up: +28 dBu (19.5 V)
- Max power @ 0.001% THD: 2.9 W per channel (!!!)
ADI-2/4 Pro SE
- Signal to Noise ratio (SNR) @ +19 dBu (Hi-Power): 120 dB (AES17), 122 dBA
- Output level at 0 dBFS, Ref Level +19 dBu, load 100 Ohm or up: +21.5 dBu (9.2 V)
- THD @ +20 dBu, 32 Ohm load (1.9 Watts): -124 dB, 0.000057 %
- Max power @ 0.001% THD: 2.1 W per channel
- Maximum output level: +27.5 dBu (18.4 V) @ 0 dBFS
- Output levels switchable: IEM +7 dBu, Lo-Power +13 dBu, Hi-Power +25 dBu
- Signal to Noise ratio (SNR) @ +25 dBu: 120 dB (AES17), 122 dBA
- Max power @ 0.001% THD: 4 W per channel
Between BBF Pro FS with 90 mW and ADI-2 series of products is quite a difference in volume to drive even the most insensitive headphones with high impedance.
