Topic: Saludos, mi interfaz se calento demasiado... HOT
Spanish:
saludos, me siento muy contento con haber adquirido mi babyfacepro. Sin embargo, me sucedio algo importante y quisiera que me dieran el soporte necesario para saber que todo esta bien.
Mi interfaz es nueva, la compre hace 3 meses, cuando la apago acostumbro a taparla con algunas mantas / sabanas / plasticos, esto, para protegerla del polvo, el caso es que sin querer la encendi y la deje tapada con las mantas encima de ella, durante 7 horas, cuando me di cuenta de la situacion, quite las mantas, y la interfaz estaba muy caliente, hirviendo, habia durado mas de 7 horas cubierta por completo, por lo que no tuvo flujo de aire en su interior, mi pregunta es, se habra dañado algo? ella enciende, trabaja con normalidad, sin embargo no se si se le habra dañado algo por dentro, debido a las horas que paso cubierta. Espero por su respuesta, gracias. No se si ella este preparada para soportar eso, o si de plano la puse en riesgo.
English:
Greetings, I am very happy with having purchased my babyfacepro. However, something important happened to me and I would like you to give me the support I need to know that everything is okay.
My interface is new, I bought it 3 months ago, when I turn it off I usually cover it with some blankets / sheets / plastic, this, to protect it from dust, the fact is that I accidentally turned it on and left it covered with the blankets on top of it , for 7 hours, when I realized the situation, I removed the blankets, and the interface was very hot, boiling, it had lasted more than 7 hours completely covered, so it had no air flow inside, my question Is there something damaged? It turns on and works normally, however I don't know if anything has been damaged inside, due to the hours I spent covered. I look forward to your response, thank you. I don't know if she is prepared to endure that, or if I just put her at risk.
