Topic: HDPSe AoX Series with Dante or Milan
Congrats @MC.  A native RME PCie Dante solution has been the dream of many a sound tech for a long time.  I am sure they will sell like hot cakes into many different market segments.
And the add-on MADI capability is just wonderful for further ROI on our current RME Madi gear.
https://rme-audio.de/hdspe-aox-d.html
https://rme-audio.de/hdspe-aox.html
Madiface XT, Madiface, 3x Micstasy, ADI8QS
Sequoia 17, W10 x64
https://bsound.co.nz/tools-nix
Re: HDPSe AoX Series with Dante or Milan
+1
HDSPe AES + HDSPe RayDat + HDSPe MADI
ADI-2 mk.1 x2 + other converters
Cubase + VEP
Do we know yet if these cards are going to get the room EQ feature?
That is unlikely as there is no dedicated DSP for such stuff. They also don't have standard PEQ in the channels. These are flexible multi-format channel monsters with advanced routing and mixing capabilities (TM FX with 256 channels...), but no sound processing as such.
5 (edited by Ninbura 2024-06-19 21:50:28)
I currently have a Digiface Dante connected to a MADI FX. This effectively gives me 64 channels of Dante over PCIe. I could technically replace these two devices with one of these, and offload DSP to my other interfaces.
I'm interested to learn more about the routing on these interfaces. The "Signal Flow" graphic is pretty confusing to me:
https://www.rme-usa.com/files/uploads/Content-Bilder/HDSPe%20AoX-D%2048k@2x.png
I would have assumed given the connection interface (PCIe x4) & the dual expansion boards, that you could technically drive 768ch in/out (512 DANTE | 128 MADI | 128 MADI). But looks like you're limited to 512ch in/out over the PCIe connection.
The other confusing bit is only being able to control 256ch via TotalMix FX? I'm not sure I understand why all channels wouldn't be exposed in TotalMix FX. Currently the MADI FX does 390 channels, all exposed to TMFX, over a single PCIe lane.
Could be that I'm just misunderstanding some of this stuff.
MADI FX | Digiface Dante | Fireface UFX+
6
Transferring 512 channels both ways on current operating systems is not a guaranteed task. Not to mention that many DAWs can't handle that amount of channels. The hardware resources in the FPGA to handle the data traffic exclude 768 channels as well.
TotalMix FX with 256 channels (rec or play) needs several tricks to work at all. The numbers of mixer knots / crosspoints and the possible combinations rises exponentially with channel count, and state changes (snapshot, workspace) need to be transferred in near real-time. There is a CPU and PCIe limit for that, 512 channels will clearly break it.
We have good reasons to limit our hardware the way it is.
Regarding MADI FX 390 channels: check the diagram again. Left is input, right is output, 256 channels go from TM FX to DAW and back, so this equals 512 channels (but for TM FX we refer to rec or play, not both summed).
Thank you for the clarifications, makes much more sense. I'll be following along to see how it all works in practice.
When I first read about the new 1620 I got the impression that it would handle both Dante and AVB. Now it looks like it is two different products? Is it the same for aox? aox-d is NOT BOTH?
AoX-M = Milan (AVB)
AoX-D = Dante
Jeff wrote:
AoX-M = Milan (AVB)
AoX-D = Dante
Thomann writes "PCIe x4 Audio Interface with DANTE Compatible AVB".  https://www.thomann.de/se/rme_hdpse_aox_d.htm
So it is not Compatible with AVB then?
11
Thomann might clarify its description once the units are available.
It seems to x8 and not x4 too. Will that be a problem for TB boxes? Mine are 2 x 4x and have room for 4 "cards" or two double width cards. Is there any TB boxes wit x8 and 3 cards so a aox with two madi extensions will work?
13 (edited by ramses 2024-09-19 17:21:54)
Where did you read PCIe x8?
According to the product page on web: https://rme-audio.de/hdspe-aox.html
"The HDSPe AoX PCIe x4 audio interface cards combine dual network ports with headphone output, AES3, MIDI, and internal expansion headers for up to four MADI ports. Whether used in a Thunderbolt™ expansion chassis or built into DAWs or audio processors, these cards send and receive up to 512 channels of audio and provide numerous mixing and routing capabilities."
https://www.thomann.co.uk/rme_hdpse_aox … p;reload=1
"PCIe x4 Audio Interface with Milan Compatible AVB"
Im looking at the images. (They are not photos) They are bigger then MADI FX. However I now realise that MADI FX is x1 not x4.
Yes.
I've also been considering the idea of using a Digiface Dante to connect to a MADI FX, for the purpose of adding Dante capability to my setup.  How are you handling clocking with this setup?  I'm kind of new to Dante but, as I understand it, the best way to deal with clocking for Dante devices is to use the clock signal embedded within the Dante signal.  However, MADI is the opposite.  It's better, if possible, to use a Word Clock connection to clock MADI devices, due to jitter with the embedded  MADI clock.
So, if you're using the Digiface to pass Dante to your MADI FX,  how are you dealing with clocking?
