Topic: Add 2 Analog Outs to UFX+?
I use a UFX+ and TotalMixFX to send output to 8 channels in a home hifi system. I would like to add 2 more analog outputs.
I also have an ADI-2 Pro FS BE. In the current setup, it serves as a USB - SPDIF converter and headphone amp. It is not connected by USB to Totalmix.
The UFX+ is clock master because I need to use the mic input on the UFX+ for clock signals in digital room correction  software.
Questions
1) Is it an option to use the ADI-2 pro AN1+2 outputs if I reconfigure to use the USB on the ADI-2 so that it shows up in TMFX? I assume that the AN1+2 outputs would be clock slave to the UFX+, as the headphone 3/4 outputs are now
2) What other options are there for 2 more analog outputs?
CURRENT SETUP
Desktop                                               Hifi Corner
miniPC
(Daphile as network streamer)
USB3
ADI-2 --------- Opt SPDIF out -------- UFX+ opt2 (AES) in
    |     --------- Opt SPDIF in --------- UFX+ opt2 (AES) out
Headphones                                             USB3 (out/in)
   AN3/4                                                        |  |
        Windows PC
        (Audio convolver for digital room correction)
The Daphile digital audio USB output is converted to SPDIF by the ADI-2 and sent by optical SPDIF to the UFX+. The UFX+ returns digital audio by optical SPDIF to the ADI-2 for headphone listening post-processing.
Clock Source is set to UFX+ so that the measurement mic ADC and speaker DAC clock are the same. This is necessary for digital signal processing in the Windows PC by Acourate (Audiovero.de).
UFX+ Analog outputs are
1+2 Subwoofers
2+4 Woofers
5+6  Mid-frequency
7+8  Tweeters
ADI-2 pro fs be; UFX+; MADIfaceUSB; Startech active USB3 cable; Sonnet Allegro Pro adapter; Win11x64
Re: Add 2 Analog Outs to UFX+?
To correct my post: I know I could connect a second UFX via MADI. I am hoping there is a less expensive option as I only want 2 more analog out connections
3 (edited by waedi 2024-06-13 03:10:37)
ADI-2 FS is the cheapest RME, with less budget there are options outside RME of course.
Waedi,
1. is it correct on the ADI-2:
- clock source set to SPDIF (incoming from UFX+)
- source for main out SPDIF (incoming from UFX+), connected to speakers (to subwoofer #3, mono)
Will the ADI-2 Main Out be clock synchronous with the UFX+, effectively an additional analog output for the UFX+?
2. For an alternative, can the UFX+ Phones out be used to drive analog speakers?
5 (edited by vinark 2024-06-13 11:22:22)
2 yes of course, with powered speakers or an amp with speakers. The phones can not drive unamped speakers of course. Audio quality will bee 100% identical to the other ufx outputs.
Plus an added benefit is the latency will be identical to the other ufx outputs. An external converter will have different converter latency.
