Topic: Audio performance close to saturation on cubase (scoring to picture)
Hello, I must be doing something wrong, I am scoring a short movies, using mostly synth, and my project is close to saturation even tho I have the buffer size set to the maximum (2048 samples).
windows 11
babyface pro fs
i9 14900k is hitting 25%
the weird thing is that the project was working fine a few weeks ago but now I need to do some last minute edits and it's getting super laggy quickly.
Any ideas ?
https://i.ibb.co/j6Tbpqj/Sans-titre.png
Re: Audio performance close to saturation on cubase (scoring to picture)
Have you got record enabled on a track? If you have asio guard enabled and then record enable a track then it will switch off asio guard and those meters will shoot up.
Hello, yes record enabled on the selected track is always ON
asio guad I believe is always enabled too
What's the best practice ? to disable asio guard ?
4 (edited by ramses 2024-08-05 13:25:14)
Take a look at the information from Steinberg and, after reading it,
give some thought to why this cannot be answered in such a generalized way…
https://helpcenter.steinberg.de/hc/en-u … and-Nuendo
If you have issues that even big ASIO buffers do not prevent audio drops, then you should check whether your system is configured properly (no energy saving, no cpu core parking, no bad driver blocking CPU cores = low DPC latency, to be measured with LatencyMon).
Another reason could be related to the DAW and project structure or the amount of VSTs and whether they suck too much performance.
If a midi track is record enabled then asio guard is bypassed. So if you are running close to the edge don’t have record enable on any midi track.
@bensmir Try to have a look which cores are running at almost full load. You have to switch the CPU graph from total use to logical CPUs.
You have big-little architecture CPU, maybe e-core is almost full load.... In that case either disabling e-cores or using utility like Lasso might help to redirect load just to p-cores....
You have strong computer and very big audio buffer. What plugins do you use? It must be something very computing heavy.... I have used such a big buffer only on rather weak very old notebook...
Hello
Sorry, I can't give you the correct answer, but if everything was fine a few weeks ago and now it has gotten worse without any significant changes, it's possible that the latest Windows July Updates (perhaps KB5040527) have altered it. I can't be sure, but we know that this can happen.
I don't use Cubase in the same scenario as you but I agree regarding the performance monitor, Windows Task Manager shows CPU performance at ~25% while the performance monitor in Cubase doesn't go below 90% but in my case at 96 Samples. Enabling or disabling ASIO-Guard hasn't helped me fix or improve this.
I'm not in a hurry, I can continue working stably according to my needs (without commitment) but if this is not your case I would contact Steinberg support, troubleshooting without qualified technical support can be tedious and frustrating for us users.
Good luck smile
UCX II FW106/34/104 v1.270 TM1.98 - PC Win11 24H2 / Fedora WS 41 - Reaper 7.33
So I am updating this thread, after getting many help in the cubase forum, sadly the issue is still there.
On a my disabled cubase template, only 6 used tracks, no mix plugin, 256 samples, and the cubase peak meter is at 50-70% during playback, sometimes it hits 100% with an audible clicks. If I improvise a line with my midi keyboard, I am easily between 50 and 70% peak meter and I overload sometimes.
We unplugged my old nvidia card, and I also did the 14f bios gigabyte update that's supposedly fixed intel 14th gen issue, I disabled core parking too
So I’m using the bfp fs and not seeing this but certain plugins do take a huge about more processing power. I can have loads running but if I use a single kontact shreddage plugin it really push the meter up
