Topic: 12mic headphone mix
Hi all. I’m considering a 12mic. Is it possible to “send” from a computer or other madi device a headphone mix from a computer to the headphones of the 12mic? Or is the headphone port only for monitoring the 12mic inputs?
(I’d like to send talk back and a back track for example to the musicians I’m recording using the 12 mic)
2 (edited by ramses 2024-07-04 06:58:12)
Re: 12mic headphone mix
On each MADI device, you configure the routing, which MADI channels to use for its inputs and outputs, same for headphone outputs.
Once this setup task has been performed, you can use the headphone outputs in TotalMix FX like any other MADI / HW output in the bottom row of TM FX.
Finally you can route any HW input and Software playback channel to it, creating an individual submix / headphone mix.
BR Ramses - HDSPe MADI FX, M-1620 Pro D, 12Mic, UFX III, ADI-2/4 Pro EX, Nuendo15, Win10 IoT Ent.
Brilliant thank you.
Sold. I’ll order one straight away!
