Topic: Make Speaker B Output Mono
I'm using a mono speaker for Speaker B to test stuff in mono. The problem is that I have to press the mono button manually whenever I switch to Speaker B. The Speaker B shows stereo in TotalMix FX, and there's no way to change it to mono by default.
How can I set Speaker B to mono (channel 3 only)?
Re: Make Speaker B Output Mono
I would not say its a problem. The Control Room A/B Feature is meant as described in the manual: Two separate monitor Pairs in a Studio. The Mono Button affects the Current selected A or B pair.
Anyhow, if you do not want to press 2 Buttons, and need only one Mono Out on Channel 3, remove it from Control Room and split it into two Mono Channels (3/4), use Mirroring, use the Cue Buttons, regarding your need,  etc...
Maybe a first starting point: https://www.youtube.com/watch?v=ZuXcu6iPcOI&t=162s
“Do It For Her”
Thanks you for the tips, I'll try those
