Topic: Feature request: Extra band for Spectral Analyser
Hi RME,
would it be possible to give the Spectral Analyser a 16Hz band at the low end?
Thanks,
Steffen.
RME User Forum → DIGICheck → Feature request: Extra band for Spectral Analyser
Hi RME,
Thanks,
Steffen.
From Digicheck's help file:
The lowest band (20Hz) goes down to the DC range and therefore shows a higher level in the case of noise.
20 Hz is already the extra band since DigiCheck NG. Before 25 Hz was the lowest one.
Yes, and this can be controlled with a toggle. I don’t want to see DC in the lowest band, hence I turn it off. I just want to see 16Hz-20Hz as the lowest band.
