Topic: Firewire 802 Main Out fader not responding
My Firewire 802 Main Out fader not responding. I have it setup as a loopback to send to IK ARC room correction (via Bidule). Whether the master fader is up or off audio still gets through. This exact setup worked fine in My Digiface HDSP.
Any ideas?
Re: Firewire 802 Main Out fader not responding
If you set an Output as Loopback, the physical Out Signal is still controllable via its out-fader. If you want to control the looped-back signal volume (i assume you use this as input for bidule?) you can use the corresponding playback fader in TM.
See chapter 27.6. in FF802 Manual.
“Do It For Her”
3
The Loopback is pre-fader in 802 and post fader in 802 FS.
That explains it, kind of a drag though. Is there a workaround?
802 user manual page 82 blockdiagram shows Loopback postfader, this diagram will receive correction ?
6
That is the 802 FS manual. It says FS directly in the drawing, on the bottom of the page., in every chapter page and on the front of the manual...
You are right
It is the wrong pdf behind the link, 802FS is linked
https://www.rme-audio.de/downloads/fface_802_d.pdf
8
Got it and fixed - thanks.
