Topic: UFX III - MADI Split (64 Channels, 96khz)
I understand the UFX III is capable of supporting up to 64 channels of MADI over both Optical/Coax using the "split" mode.
My current setup is 32 channels of 96khz audio coming in from 2 Ferrofish Pulse 16's (MADI Format: 64 (32ch), MADI Frame: 96K Frame). One Ferrofish Pulse 16 running via ADAT into a Ferrofish Pulse 16 MX running into the optical MADI ports on the UFX 3.
I'm planning to add another Pulse 16 MX with SFP Coax module into the Wordclock ports on the UFX 3 (with the potential for another Pulse 16 routing into the MX over ADAT in the future).
My main question is: does sample rate matter here in the way that it does with ADAT? Would the UFX III support all 64 channels of 96khz audio from up to 4x Ferrofish Pulse 16's using the MADI "Split" mode?
Some follow up questions:
Would there be any potential clocking issues with that I'm missing? Currently I'm not having to use the wordclock cables and the two Pulse 16's are synced perfectly. I'm assuming/hoping this will continue to be the case with two more Pulse 16's over MADI Coax as long as I'm using the UFX III's internal clock.
Any advice on BNC/Coaxial cables here? I've never used these before and it seems like there are a lot of options available.
Uncertain about the relevance of / correct option for "Word Clock Termination" settings in this case.
Also uncertain about the relevance of / correct option for "Word Clock I/O Single Speed" settings here.
Regarding the remaining ADAT I/O: If I were to use this in the future, would I been hampered by the fact that I no longer have Word Clock available? I've noticed that some devices seem to sync just fine without WC (Pulse 16), while some seem to require it (Quantum 2626). Is there some way to know whether or not a device can reasonably stay clocked/synced over ADAT alone? For instance, the H9000?
I think this setup should work perfectly fine, but there are some details I'm uncertain about and I just wanted to seek a bit of clarity before pulling the trigger on this upgrade.
