Topic: dmc842 src vs mode2 questions
I've been using the 842 with 4 neumann mode 2 mics and about 30 feet of aes cable to each mic. with no issues. I can also switch on src, and I can't detect any difference in the sound with these mics.
Is it really doing any sample rate conversion? Do the mode 2 mics free run from an internal crystal when you turn on src, or is src just ignored?
Can RME provide any analysis for a choice between using SRC or using the mode 2 control? I'm particularly interested in relative stability of the mode 2 control vs using SRC as the cables get longer, as I am considering a setup with cables running 120 feet.
