Topic: clock sync and best A/D
Hello, I got the following equipment:
HDSP9652
ADI PRO
ADI ANIVERSARY EDITION
ADAT XT20
I think that the best digital clock is the one from de ADI AE, is right? I use this as master clock, is this the best option or I should use the HDSP9652 clock?
I only use 8 inputs of A/D, what should I use? the ADI pro? or the ADI AE?
Pedro
Re: clock sync and best A/D
I would use the HDSP for convenience reasons. The clock quality is not inferior to that of the AE.
I would prefer choosing the A/D as clock master. I think this generation of converters performs best when running free.
Can't tell which of the converters has the better A/D: As I understand it, the AE has slightly inferior A/Ds than the DS, but in comparison to the Pro...?
I read that the clock of the ADI EA is the same of the ADI DS, and I better than the HDSP isn't?
Best regards
pedro
Maybe the clocks are the same, but I think the point is that the ADI-8 Pro/AE/DS perform better when they follow their own internal clock. The QS has steady clock, which changes the situation.
Ulrich
Only one device can be clock master, so at least one converter will have to be clocked externally anyhow...
So true...
