1 (edited by Lerian 2024-08-28 06:46:33)
Topic: [Solved] Window Bug when saving workspaces/snapshots
Since the last update (not sure if the previous one too since I haven't tried), I have this weird problem with the save window in TMFX - the file path field doesn't show. It does show when loading though.
Its not impossible to save, just make it way harder - need to make an empty file first with tmws extension, then search for it and replace.
Here it is, in all its weirdness:
https://i.imgur.com/Sr6s1T3.png
Windows 11 Pro 23H2
TMFX v 1.95 (LE: also present in 1.96 beta 7)
Driver 1.251
Thank you.
Re: [Solved] Window Bug when saving workspaces/snapshots
Does it help to resize that dialog?
Did you try to Save a Snapshot or a Workspace? Or do both show this?
No one has vever seen this effect and we did not change any routines for this at all, so it seems there is something very unique on your Windows installation causing this.
Sorry, I just found the problem - there's a program called Rectify11 that I use to make Win11 consistent with the black theme. Normally all the win32 windows are white, even when using the black theme. Disabling the Rectify11 settings makes it work just fine.
Its weird that only on TMFX does that, so far.
