Topic: EQ Audeze LCD GX
Hallo,
kann mir wer weiterhelfen wie ich diesen EQ bei meinem ADI 2 DAC FS eingebe (ich kann ja nur 7 Band eingeben)
https://www.reddit.com/r/oratory1990/co … e_1352024/
vielen Dank
Re: EQ Audeze LCD GX
https://www.dropbox.com/scl/fi/34snspl7 … 2&dl=0
3 (edited by KaiS 2024-09-03 23:57:10)
The closest approximation would skip bands 3, 5 and 9, and shift f4 to 900 Hz.
This EQ is too detailed anyway, and is set with higher resolution than the Harman target curve has (for a good reason that all people have different anatomy).
You can’t correct higher than you measure, or you will introduce errors instead of corrections.
So it’s a good idea to leave away narrow band corrections above ca. 2-3 kHz, where measurement accuracy doesn’t meet your personal anatomy anyway.
